Reversing at night or in low light situations
- NewDelica91
- Vehicle: 1991 Delica L300 Starwagon
So I was coming home a few days ago from a nice day out and was trying to reverse into my parking spot and notices it was hard to see where I was going as my reverse lights seemed dim. Is there a brighter bulb out there? I had considered getting a LED light kit and mount a separate switch. Any thoughts or ideas would be awesome!
Sent from my SM-G930W8 using Tapatalk
Written from underneath my Delica, just kidding!
204explorer
- Vehicle: l400
Here is my solution for this problem. Two inexpensive LED flood lights from Amazon. Powered by a relay that is either energized when the reverse lights come on and also by a switch in the dashboard. Helpful whe loading the van at night or when you hook up a trailer. It is working good for me.[img]https://uploads.tapatalk-cdn.com/201803 ... 064aab.jpg[/img][img]https://uploads.tapatalk-cdn.com/201803 ... 6f0d09.jpg[/img]
Sent from my SM-G950W using Tapatalk
- Lapprentis
I did replaced the backing stock light with LED and it helped at lot: I mean very significant: will try to show the result and picture the bulb too soon
Lapprentis
Lapprentis
- NewDelica91
Awesome! I'll be checking out Amazon tonight and see what I can find. Thanks 204explorer!204explorer wrote:Here is my solution for this problem. Two inexpensive LED flood lights from Amazon. Powered by a relay that is either energized when the reverse lights come on and also by a switch in the dashboard. Helpful whe loading the van at night or when you hook up a trailer. It is working good for me.[img]https://uploads.tapatalk-cdn.com/201803 ... 064aab.jpg[/img][img]https://uploads.tapatalk-cdn.com/201803 ... 6f0d09.jpg[/img]
- NewDelica91
I like this idea as well. When you can post the pics I would like to see what bulbs you used. Do you remember where you purchased them from?Lapprentis wrote:I did replaced the backing stock light with LED and it helped at lot: I mean very significant: will try to show the result and picture the bulb too soon![]()
Lapprentis
Jumboshrimp
- Vehicle: Mitsubishi Delica
I installed these in the reverse lights and the difference is huge!
https://www.amazon.com/gp/product/B01H5 ... UTF8&psc=1
- NewDelica91
Sorry Jumboshrimp link didn't work.Jumboshrimp wrote:I installed these in the reverse lights and the difference is huge!
Ralph in Winnipeg
- Vehicle: 94 Strada
I just replaced the stock bulbs on my Townace. The 1157 bulbs don't look that much brighter but the 1156 ones are at least twice maybe three times as bright as the originals.
I ordered them off amazon.ca
LUYED 5 x 900 Lumens 12v-24v 1156 1141 1003 3014 78-EX Chipsets Led Bulb Used For Back Up Reverse Lights,Brake Lights,Tail Lights,Rv light,Xenon White(Best Choice Of High Brightness)
Sold by Hot Light Team
Condition: New
5 bulbs for $25 is pretty reasonable as well.
Ralph in Winnipeg
Condition: New
Ralph in Winnipeg
Jumboshrimp
@ Ralph in Winnipeg
the bulbs I used were the 1700 LUMEN version of what you posted.
$19 US for 2 bulbs
I went with the brightest I could find!
I also used in the front side illuminators! Super bright when that signal turns on!
sorry link didn't work @NewDelica91
$19 US for 2 bulbs
- NewDelica91
Hey, Jumboshrimp I actually got the link to work on my computer so it's all good. Thanks for the info.
- Lapprentis
Here it is, a CREE Led Light bought on Ebay a while ago...sorry, not part number on it...One is with reverse light on (the Suzuki is 10M away) and the other on without it
Now, if you have tinted glass....you may need something more powerfull
Lapprentis
Lapprentis
- IMG_6271.jpg (397.35 KiB) Viewed 15948 times
- IMG_6392.jpg (290.88 KiB) Viewed 15948 times
- IMG_6269.jpg (552.38 KiB) Viewed 15948 times
- IMG_6393.jpg (174.79 KiB) Viewed 15948 times
volnoir
- Vehicle: 95 L400 Super Exceed
Will these lights fit in a L400 as well or do they use a different chipset?
I use the Force.
