L400 rear hatch weight
blevesque@shaw.ca
Vehicle: 96 l400 super exceed
Post by blevesque@shaw.ca »
Anyone know the weight of the rear hatch? I'm in Calgary and trying to get some replacement struts made locally. They need to know the length of the originals struts and the weight of the hatch.
tonydca
Re: L400 rear hatch weight
Post by tonydca »
If you contact this guy in BC:
www.strutwise.com
consider taking off your old ones and overnight 'em for a rebuild.
This guy really knows his stuff; his opinion that OEM Mitsu ones are very well built, and that the few worn bits that he replaces makes 'em better than new.
Fairly reasonable, and he claims to guarantee them forever. "The rest of your vehicle will wear out before they do." Two years ago and they still work great.
CREGAN
Post by CREGAN »
Hey Tony- do these rebuilt struts hold the door up again? I have a chrome Jaos ladder so can they be recharged to take that into account. I am so tired of hitting my head on the door!
Craig
Tell him what you have additional on the rear hatch and he will re-charge the struts to suit a heavier load. Super nice guy.
tonydca
Post by tonydca »
CREGAN wrote:Hey Tony- do these rebuilt struts hold the door up again? I have a chrome Jaos ladder so can they be recharged to take that into account. I am so tired of hitting my head on the door!
Craig
Forgot to mention; I have a pretty heavy Terzo ladder on mine and no problems:
http://www.delica.ca/forum/looking-for- ... tml#p71781
They are skookum shocks once this guy is done with 'em. 8-)
thelazygreenfox
Post by thelazygreenfox »
blevsq
I added a piece of 1/2 " cutting board under my top hinge to raise my L400 hatch a little more. Trace out your top hinge and cut out with a jig saw or(?). Lengthen the bolts by a 1/2 inch too.
Any thicker a shim and the tail gate won't close.
You still need a re&re on the hinges if the tail gate won't stay up . Don't forget to brace the tailgate up when you remove the hinges.
Wayne
TLGF
RichD
Post by RichD »
Also don't prop up your hatch with a stick leaning against the plastic molding of the rear tail light. Even the slightest touch of the hatch will break it and then you might be inclined to blame another party for falling into the trap you set.
tonydca
Post by tonydca »
RichD wrote:Also don't prop up your hatch with a stick leaning against the plastic molding of the rear tail light. Even the slightest touch of the hatch will break it and then you might be inclined to blame another party for falling into the trap you set.
Or a tent peg :-(
Diver
Vehicle: L400
Post by Diver »
First post over here so Hi Canada!
Just in case you still need the info, I ordered some struts for mine the other day. Mine's a high-roof with a Terzo and standing on some scales holding the tailgate above my head with the struts disconnected, I found I'd put on 22kgs :-) . The strut length extended is 770mm and retracted 620mm. I ordered 20mm longer to get a bit more height (the tailgate will go up quite a bit before it fouls the bodywork).
thelazygreenfox
Diver
How much did you pay for the struts and where did you order them from?
Let us know how the extra height you have at the end of the tailgate. :-D :-D
thanks
TLGF
Diver
Vehicle: L400
Post by Diver »
I paid £64 GBP for the pair and ordered them from here using the 'strut builder tool':
http://www.sgs-engineering.com/
Went for the adjustable force type which come with a huge amount of pressure which you slowly bleed out until they are the force you require. I'm going for 'unexpected uppercut to the chin' :mrgreen:
I'll let you know how they work out.
Diver
Vehicle: L400
Post by Diver »
Fitted the struts today and the extra 20mm of strut length equates to an extra 20cm of tailgate opening height.
Before
Before
After
After
The extra pressure means it lifts the tailagate and ladder easily all by itself. :-D
MOV04290.MPG
(407.41 KiB) Downloaded 469 times
ccautos
Vehicle: 92 Delica SE
Post by ccautos »
You could flip pancakes off the back of that !!!
P.Gaudreault
Vehicle: Mitsubishi Delica 1998 Chamonix
Post by P.Gaudreault »
Does someone order these strut from http://www.sgs-engineering.com/ here in Canada?
bitnaut
Vehicle: 1995 Royal Exceed PD6W
Post by bitnaut »
I recommend you get your struts refurbished at http://strutwise.tech in Surrey BC. Frank makes them good as new.
Just a satisfied customer.
Return to “L400 Technical”
