Help!
Yesterday Deloris started choking and now she won't go more than 2000 rpm. Engine seems to be running smooth but no pick-up-and-go. VERY sluggish. Still moves up through the gear as it gains speed. But no umph/jam when you hit the gas.
Has anyone had a similar issue?
Brad
Won't go > 2000 rpm
fozzie
- Vehicle: '90 delica exceed
Won't go > 2000 rpm
What does the exhaust look like? Does it stutter at all? Like a fuel problem?
- Growlerbearnz
- Vehicle: Delica P25W
Won't go > 2000 rpm
Is this petrol or diesel? On a diesel it might be the boost line going to the injection pump- if that comes off or splits it'll act like a non-turbo engine (though I'd expect it to still rev past 2000rpm, eventually). Symptoms would include a new hissing noise from under the bonnet at high revs, and more black smoke out the exhaust than usual.
I'm guessing it starts and idles just fine.
pajerry
Won't go > 2000 rpm
Also check the Throttle Position Sensor.
Lots of posts, easy to tune up, makes a huge difference how the vehicle shifts. I do mine yearly as it starts to waver.
