Oil Leak from Vacuum Pump
sfd_656
- Vehicle: l400
Our 1996 l400 recently sprang a leak from what i think is the vacuum pump (passenger side of the engine compartment on the front of the motor with a line running to the brake booster). It appears that the top piece is broken off? Does anybody have any insight? What is the black plastic part that looks broken? Is the pump rebuild-able with some o rings?
poochike
- Vehicle: 1999 L400 Chamonix Gen2
I'm pretty sure that's your oil pressure sender. Common problem, easy fix. CVI, RJD, Amazing Auto, Rising Sun, Coombs Country Auto will all have the part. About $20 if I remember correctly. I carry a spare with me just in case.sfd_656 wrote:Our 1996 l400 recently sprang a leak from what i think is the vacuum pump (passenger side of the engine compartment on the front of the motor with a line running to the brake booster). It appears that the top piece is broken off? Does anybody have any insight? What is the black plastic part that looks broken? Is the pump rebuild-able with some o rings?
sfd_656
- Vehicle: l400
Thank you, does the fix just involve removing the old sender and threading in the new one and reattaching the wire? What causes them to break? I have the new part on the way.
poochike
That's it. Believe it's a 22mm deep socket or a small adjustable wrench to remove the old one. They're just a weak point in the system. Usually the wire connection doesn't bust off, it just leaks from the top. Maybe yours was bumped from some recent work to cause the wire connection to bust off? There's a through bolt underneath that attaches to the banjo. If this comes out with the oil sender be careful not to lose the 2 copper washers.sfd_656 wrote:Thank you, does the fix just involve removing the old sender and threading in the new one and reattaching the wire? What causes them to break? I have the new part on the way.
sfd_656
- Vehicle: l400
Thanks again.
poochike
You get things sorted?sfd_656 wrote:Thanks again.
sfd_656
- Vehicle: l400
Parts just arrived and getting dark outside will have to wait until friday. Old sensor needs a 1 1/8" deep socket (will have to borrow one, new one from mardy fits in a 24mm deep socket
sfd_656
- Vehicle: l400
All done, leak is cured.
poochike
Nice one.sfd_656 wrote:All done, leak is cured.
P.Gaudreault
- Vehicle: Mitsubishi Delica 1998 Chamonix
I have the same oïl leak with my 1998. Thank for all these good info. Is It possible that this leak make the engin cough at a different speed? Like all the van is shaking.
poochike
No, it will not cause the van to shudder or have performance issues. That is unless you lose all your oil before noticing!P.Gaudreault wrote:I have the same oïl leak with my 1998. Thank for all these good info. Is It possible that this leak make the engin cough at a different speed? Like all the van is shaking.
sfd_656
- Vehicle: l400
The leak gets worse quickly, order parts and repair asap, check/add oil every time you drive the vehicle until repaired.P.Gaudreault wrote:I have the same oïl leak with my 1998. Thank for all these good info. Is It possible that this leak make the engin cough at a different speed? Like all the van is shaking.
P.Gaudreault
Ok Thank you for the advice. I will order the part ASAP.
Delica_Acadie
- Vehicle: Mitsubishi Delica Exceed L400
poochike wrote:I'm pretty sure that's your oil pressure sender. Common problem, easy fix. CVI, RJD, Amazing Auto, Rising Sun, Coombs Country Auto will all have the part. About $20 if I remember correctly. I carry a spare with me just in case.sfd_656 wrote:Our 1996 l400 recently sprang a leak from what i think is the vacuum pump (passenger side of the engine compartment on the front of the motor with a line running to the brake booster). It appears that the top piece is broken off? Does anybody have any insight? What is the black plastic part that looks broken? Is the pump rebuild-able with some o rings?
Hi there so is this the part : oil pressure switch : http://www.ccautos.ca/4d56-4m40-oil-pressure-switch/
I am trying to attach a pic of mine on my van. I noticed it cause the part is a wet and black and the top bug is loose...so make me wonder if i need a plug as well that goes on the oil pressure switch.
- Delica Forum.jpg (491.03 KiB) Viewed 13489 times
poochike
The plug on mine also sits loose, but I don't think it's a problem. As long as it's doing it's job. If you don't see the oil light come on when you start the van then perhaps you do need a new connector.Delica_Acadie wrote:poochike wrote:I'm pretty sure that's your oil pressure sender. Common problem, easy fix. CVI, RJD, Amazing Auto, Rising Sun, Coombs Country Auto will all have the part. About $20 if I remember correctly. I carry a spare with me just in case.sfd_656 wrote:Our 1996 l400 recently sprang a leak from what i think is the vacuum pump (passenger side of the engine compartment on the front of the motor with a line running to the brake booster). It appears that the top piece is broken off? Does anybody have any insight? What is the black plastic part that looks broken? Is the pump rebuild-able with some o rings?
