leaking fuel pump
Flounder
- Vehicle: 1991 Delica l300
leaking fuel pump
So I just changed where I get diesel from Super Store to Shell. Van is running much better already. Starts easier, smokes less, better mileage. HOWEVER since doing this my fuel pump is leaking. not sure exactly but thinking from the two bolt on plates on the side of pump. Is there any connection to fuel change to leak???????????? Note. never leaked before running other fuel.
- JoeMag
- Vehicle: L300 Crystal lite roof 5spd
leaking fuel pump
Most of the time they will leak from the two plates at the bottom of the pump on both sides. there is also the seal at the back of the pump kind of between all the fuel lines. The latter can be replaced without taking the pump out of its hole but not the bottom ones.
Flounder
leaking fuel pump
Was thinking it was leaking from those plates. Is it just a gasket on each that need to be replaced?
- JoeMag
leaking fuel pump
yep O rings actually.
Flounder
leaking fuel pump
so with a little further investigating it appears that the pump is leaking from top gasket on engine side. Should I just have whole pump rebuilt?
- pump.JPG (44.38 KiB) Viewed 14161 times
- Growlerbearnz
- Vehicle: Delica P25W
leaking fuel pump
If you've pulled it apart that far you might as well buy a rebuild kit (http://www.ebay.com/itm/GASKET-KIT-REBU ... Gs&vxp=mtr) and replace the seals yourself. I'm guessing you've seen the Gnarlodious VE pump rebuild how-to? http://gnarlodious.com/vanagon/bosch_pump/-Rebuild
Killbert
- Vehicle: 91 Delica Chamonix
leaking fuel pump
Oh man that looks exciting
Sent from my SAMSUNG-SM-G891A using Tapatalk
- Growlerbearnz
leaking fuel pump
...for certain definitions of "exciting", yesKillbert wrote:Oh man that looks exciting
- muk138
- Member's Photo Album: http://instagram.com/marcus_leite
- Vehicle: Delica L300 Super Exceed
leaking fuel pump
On this topic, I been trying to track down instructions for replacing the seals.
Anyone find anything posted or done this and willing to explain?
- Growlerbearnz
leaking fuel pump
Check out the Gnarlodious link in my previous post.
- deskinthewoods
- Vehicle: 1991 L300 Star Wagon named "Wilson"
leaking fuel pump
Anybody have a copy of what was on the Gnarlodious link? It seems to no longer be alive...
- Growlerbearnz
leaking fuel pump
Here's a copy of it: http://www.brick-yard.co.uk/forum/ve-in ... 17456.html
Ried363
- Vehicle: Mitsubishi Delica L300
leaking fuel pump
Working on solving a leak and want to replace some O-rings without removing the whole pump. The main leak is coming from the distributor head high pressure pump (the thing in the middle of the fuel injection lines).
What kind of specialty socket can remove that? It has three flat and three round sides. About 22mm. Very bizzare...
Please help!
Please help!
- deskinthewoods
leaking fuel pump
https://www.ebay.com/itm/3pcs-Socket-Se ... :rk:3:pf:0
Just bought these. Perfect fit.
You’ll need to remove the top two injector pipes to get the socket in and it’s a very fine thread on that centre bolt so just keep unscrewing until it comes off. Easy o-ring swap. Minimal fuel spillage. Prime the injectors you disconnected (loosen the other end of the pipe at the injector a half turn, crank the starter until fuel leaks out and retighten (as per Growlerbearnz’s instructions))
