Battery drain
crazy4two
Vehicle: 1991 Delica L300
Battery drain
Post by crazy4two »
So my door ajar warning light on the instrument clutter is always illuminated even though my doors are all closed. The light even illuminates when the key is not in the ignition and the car is parked. Well on several times now, because the car is not a daily driver, I have come out to find my battery dead. I am assuming the problem comes from that warning light always on.
So my question is does anyone know if there is a fuse that I can pull which controls that light? My fuse box of course is in Japanese so I can't read it. Or can I cut a wire from either my sliding door or tailgate to at least turn that light off?
tomaboyd
Vehicle: 1991 Delica Exceed
Battery drain
Post by tomaboyd »
Use this for reference. Looks like #1
cosmo727
Vehicle: 1996 Delica Starwagon Active World
Battery drain
Post by cosmo727 »
I do a lot of camping in my Delica and the doors are open quite a bit at the camp sites. I ended up pulling the instrument cluster (very easy, there's a how to somewhere on the site) and removed the door ajar lamp.
crazy4two
Battery drain
Post by crazy4two »
I like that idea of removing the bulb. I'll research that thanks.
Sent from my iPad using Tapatalk
ChuckBlack
Vehicle: L300 Jasper
Battery drain
Post by ChuckBlack »
ground controlled at all door locations.
L300 Jasper, :-D
L300 Chamonix, :-)
Pajero Mini, :-(
Pajero GDI :o
Pajero DiD 8-)
ChuckBlack
Battery drain
just take 1/2h of your time and properly troubleshoot the cause. probably have a bad connection with the door warning switches instead! Then when you're ready to sell at least it's done professionally!
L300 Jasper, :-D
L300 Chamonix, :-)
Pajero Mini, :-(
Pajero GDI :o
Pajero DiD 8-)
