CV Boot Strap
stever1000
Vehicle: 94 L400 SuperExceed
CV Boot Strap
Post by stever1000 »
Does anyone know where I can get the strap and tool to secure the CV boot to the hub? I previously used heavy duty zip tie (as recommended by someone else) but it slipped off. Sorry for the bad pictures, here is the spot WITHOUT the strap
stever1000
CV Boot Strap
I know the tool can be bought from princess auto, but the van is on stacks right now and I can't drive there.
Is there a locally available replacement strap I can use instead of getting OEM? What's the length?
kurtiswilk
Vehicle: 97 L400 super exceed
CV Boot Strap
Post by kurtiswilk »
Pretty sure that princess sell the straps too
Deli Duncan
97 L400 gen 2
thelazygreenfox
CV Boot Strap
Post by thelazygreenfox »
Princess sells stainless straps that self tighten. They're good, i've used them a lot on boots. Wind up the ends to tighten w needle nose pliers. Clip off the excess with side cutters.
stever1000
CV Boot Strap
thelazygreenfox wrote:Princess sells stainless straps that self tighten. They're good, i've used them a lot on boots. Wind up the ends to tighten w needle nose pliers. Clip off the excess with side cutters.
Thanks, are these the kind that don't require any special tools, only pliers as you mention?
thelazygreenfox
CV Boot Strap
yup
