best "ignition" wire to tap into (beneath steering wheel)
lookoutworld
Vehicle: 1990 P25W - 5 speed
Post by lookoutworld »
Hello!
I'm putting in a boost/EGT gauge tomorrow and it has a "12V continuous" lead and a "12V ignition" lead. My gut wants to splice into the cigarette lighter wire... but I've read accounts that these wires can't handle much draw and I already have two other devices (TM2 and a dashcam) running off that cigarette plug.
Does anyone have a recommendation for a robust wire to splice into for the "12V ignition" lead? Preferably beneath the steering wheel?
Thanks in advance!
-Scott
Overlanderjay
Vehicle: Ford E350 Econodeli powerveg
Re: best "ignition" wire to tap into (beneath steering wheel)
Post by Overlanderjay »
Black is power feed Blue with white stripe is power on at "on" & "start ". blue is power at. "On " & "acc" Blue with the white stripe is power at "on". Black with yellow stripe is starter motor .
"Electrickery Technition"
Lapprentis
Post by Lapprentis »
What about the Orange wire from under the steering ?
Lapprentis :M
Overlanderjay
No orange wire on the ignition side maybe on the headlight/turn signal/wiper side .
Lapprentis
I am no electrical expert,, but my daytime running lights are, from what I remember on an orange wire, from the steering....
Will Check again...
Lapprentis :M
lookoutworld
OK, so I finally dug into this.
Apparently my wires a bit different!
Anyone know what these colors could correspond to?
1) Black
2) *Black* with white stripe
3) Black with red stripe
4) Black with yellow stripe
5) Blue
6) Blue with red stripe
7) more smaller ones...
Picture1:
File Sep 07, 11 46 50 PM smaller.jpeg (620.79 KiB) Viewed 6516 times
Picture 2: (you can see the spliced wires.. not sure what these are yet)
File Sep 07, 11 45 57 PM smaller.jpeg (593.6 KiB) Viewed 6516 times
And this is from DinoEvo's 1990 L300 (europe) wiring diagram:
Screen Shot 2016-09-07 at 11.45.08 PM.png (153.82 KiB) Viewed 6516 times
Furi
Vehicle: 1990 L300
Post by Furi »
Have u considered tapping into the fuse box? You can check which fuse is what and use one of those fuse extension thingies to make it super easy and clean.
Furi
Vehicle: 1990 L300
Post by Furi »
.... and to attest to the cigarette lighter wiring load limit. Used mine to run a compressor(12 V, 15 AMP) and I think it burned out the wiring. The 15AMP fuse of the lighter is fine.
TieMyShoe
Vehicle: L300
Post by TieMyShoe »
dont tap into any wires.... buy a fuse tap and go from the fise block. Safer, more reliable, no hacking up factory harnes.
