First Hiccup
Ralph in Winnipeg
- Vehicle: 94 Strada
First Hiccup
I couldn't shift into gear the other day. After some research, I bled the clutch slave cylinder with my vacuum pump (which made it super easy). Lots of bubbles at the start and then just a thin stream of little ones. Clutch seems to work now..... Not sure if the problem is fixed or not so we'll have to see. Found the previously mentioned rebuild kit on the net if it comes to that, thanks strada92!
Ralph in Winnipeg
Re: First Hiccup
Rebuild kits are quite rare apparently. Luckily, the 3/4" bore slave cylinder is very common. Bought a cheap Mazda slave cylinder and slipped the piston into the stock Strada one and we are good to go.
