 : when I  did look from the top of the engine (engine bay), I can see a small wire (S Terminal) clipped through a plastic connector on the top of the Magnetic Switch, above much larger wires (B and M terminals). 2 wires start from there and goes up to the battery compartment. Wich one is the Ground ?
 : when I  did look from the top of the engine (engine bay), I can see a small wire (S Terminal) clipped through a plastic connector on the top of the Magnetic Switch, above much larger wires (B and M terminals). 2 wires start from there and goes up to the battery compartment. Wich one is the Ground ?Thanks
Lapprentis
