Ultimate Oil Filter X-Reference
Found this info looking for a shorter filter. Seems to have almost every filter brand I can think of. Use @ your own risk of course! A jpg to view and a pdf to save.
				- Oil Filter X-ref.pdf
- (265.9 KiB) Downloaded 411 times
				- Oil filter x-ref.jpg (38.54 KiB) Viewed 4534 times
- Growlerbearnz
- Vehicle: Delica P25W
Re: Ultimate Oil Filter X-Reference
Nice! Do you still have access to the original text? Any chance you could copy and paste the text into a post? (even just the cross-reference list would be handy)  The .jpg and .pdf are great, but the actual text would be searchable on the forum.
						- Growlerbearnz
Sweet! I'll just leave this here and tidy it up later:
MITSUBISHI MD069782
Length: 135MM
Outside Diameter: 102mm
Anti Drain Valve
Thread Size: N/A M26 x 1.5
Gasket OD: MM 73
Gasket ID: MM 45
Donaldson Part Number P551343
Cross Reference A E C WHITLOCK: MC400, MO400 - AC: PF2147 - ALCO: SP997 - AMC: J1315005H135, MO400, OC15070, OC15071, SC306, SC306H135, SFO9782ML, SFO9782NML, T7317H125 - AMERICAN PARTS: 92067 - ASAHI: 400K, MO400 - BALDWIN: BD28 - BIG A: 92067 - CARQUEST: 85067 - CHAMP: C321, C321H135 - CHAMPION LABORATORIES: LFP805 - CHRYSLER: MD069782 - CLEAN: DF827 - COOPERS: Z1041 - CROSLAND: 2087 - EXMAN: J1315005H135, MO400, OC15070, OC15071, SC306, SC306H135, SFO9782ML, SFO9782NML, T7317H125 - EXXEL PTY LTD: 14640060 - FLEETGUARD: LF3564, LF3564H125 - FLEETRITE: LFR83564 - FORD: E5TZ6731A - FRAM: PH6355 - FSA: FO1097 - GM: 25171958 - GREYFRIARS: 9024S - HASTINGS: LF147 - HYUNDAI: 2630042010, 2630042030, 2630042040 - KIA: K55114302, OK55114302 - KRALINATOR: D3 - LUBER-FINER: LFP805, LFP9930 - MANN & HUMMEL: W93026, WP92881 - M-FILTER: MH3346 - MICROPORE: T7317 - MITSUBISHI: ADC42105EH135, MD069782, MD069782H125, MD069782H135, MD069782MLH, MD184086, MDO69782 - MOTORCRAFT: FL805 - NAPA: 1067 - NIPPON: J1315005 - P.B.R.: BC1211 - PARTMO FILTERS: AD092 - PTPJM: J8610782 - PURFLUX: LS740A - PUROLATOR: L34750 - RYCO: Z313 - SAKURA: C1008, C10081, C10082, C10083, C10085, C2906, C8024 - SAVARA: SO564 - SOFIMA: S1001DR, S1001DRH135 - SURE FILTER: SFO47501, SFO9782ML - TECNOCAR: RD1001 - TEXACO: HSO135 - TOKYO ROKI: C306 - UFI: 2323700, 2323700H135 - VIC: C306 - VMC: LF551343 - WIX: 51067, 551067, 59222 - WOODGATE: WGL3564
							MITSUBISHI MD069782
Length: 135MM
Anti Drain Valve
Gasket OD: MM 73
Gasket ID: MM 45
				psychedelica
- Vehicle: 1991 Exceed
Updated Growlerbearnz's excellent post with more info from http://www.yoyopart.com, http://www.filterspro.com and reformatted for easier reading. (As before, use @ your own risk, but you're probably OK if the specs of your filter are equal or better to Mitsubishi specifications shown below.)
Mitsubishi Oil Filter MD069782
Specifications
Length: 135MM
Anti Drain Valve
Thread Size: M26 x 1.5
Gasket OD: MM 73
Gasket ID: MM 45
Efficiency Beta 2: Micron 16
Relief Valve Setting: Bar 0.80-1.00
Other Manufacturers' Equivalent Filters
AC: PF2147
ACDelco: X4252E
ALCO: SP997
AMC: J1315005H135, MO400, MO-400K, OC15070, OC15071, SC306, SC306H135, SFO9782ML, SFO9782NML, T7317H125
ASAHI: 400K, MO400
ASHIKA: 10-05-505P
BALDWIN: BD28
BIG A: 92067
BOSCH: 0 986 452 042, P2042
CARQUEST: 85067
CHAMP: C321, C321H135, LFP 805
CHAMPION LABORATORIES: LFP805, K 270, K270/606
CHRYSLER: MD069782
COOPERS: Z 1041
CROSLAND: 2087
DELPHI: FX0152
DONALDSON: P 50-2061
FIAAM: FT5151
FILTRON OP 587
FLEETRITE: LFR83564
FORD: E5TZ6731A
FRAM: PH6355
FSA: FO1097
GM: 25171958
GREYFRIARS: 9024S
HASTINGS: LF147
HENGST FILTER: H209W
HYUNDAI: 26300-42000, 2630042010, 2630042030, 2630042040
JAPANPARTS: JFO505, J FO-505P, J FO-505S
KRALINATOR: D3
M-FILTER: MH3346
MAGNETI MARELLI: 150290100100
MANN-FILTER: WP 928/81
MAZDA: VSY3-14-302, VSY1-14-302A
MEAT & DORIA: 15037, 15037/12
MECAFILTER: ELH4224
MICRO FILTER: T7317
MICROPORE: T7317
MITSUBISHI: ADC42105EH135, MD069782, MD069782H125, MD069782H135, MD069782MLH, MD184086, MZ690071, 1230A045, 1230A045C, 1230A114
MOTAQUIP: VFL304
MOTORCRAFT: FL805
NAPA: 1067
NIPPON/NIPPARTS: J1315005
P.B.R.: BC1211
PTPJM: J8610782
PURFLUX: LS740A
PUROLATOR: L34750, L37733, L27998
QUINTON HAZELL: WL7154
RYCO: Z313
SAUDI FILTER: SF55
SAVARA: SO564
SOFIMA: S1001DR, S1001DRH135, S 3454 DR
TECNOCAR: RD1001
TEXACO: HSO135
TOKYO ROKI: C306
UNICO FILTER: BI 10126/81
UNIPART: GFE 329
VIC: C306
VMC: LF551343
WOODGATE: WGL3564
Specifications
Length: 135MM
Anti Drain Valve
Gasket OD: MM 73
Gasket ID: MM 45
AC: PF2147
ACDelco: X4252E
ALCO: SP997
ASAHI: 400K, MO400
ASHIKA: 10-05-505P
BALDWIN: BD28
BIG A: 92067
CARQUEST: 85067
CHRYSLER: MD069782
COOPERS: Z 1041
CROSLAND: 2087
DELPHI: FX0152
FIAAM: FT5151
FILTRON OP 587
FLEETRITE: LFR83564
FORD: E5TZ6731A
FRAM: PH6355
FSA: FO1097
GM: 25171958
GREYFRIARS: 9024S
HASTINGS: LF147
KRALINATOR: D3
M-FILTER: MH3346
MECAFILTER: ELH4224
MICRO FILTER: T7317
MICROPORE: T7317
MOTAQUIP: VFL304
MOTORCRAFT: FL805
NAPA: 1067
P.B.R.: BC1211
PTPJM: J8610782
PURFLUX: LS740A
RYCO: Z313
SAUDI FILTER: SF55
SAVARA: SO564
TECNOCAR: RD1001
TEXACO: HSO135
TOKYO ROKI: C306
UNIPART: GFE 329
VIC: C306
VMC: LF551343
WOODGATE: WGL3564
