This summer we have had two instances where the A/T light has come on. First was driving up a steep fsr outside of salmon arm it was about 35oC that day and we were about 15km up. we stopped loooked around for 25min and got back in started up and light was off and remained off for the next 10km to where we stopped. Then this weekend similar situation only steeper out of revy, but only 20oC outside. at about 15km up light came on, we stopped it cooled down and we continued on.
Now that we have overheated the fluid twice is it time for a change? if so where is the drain and what volume do I need to add? any sugestions on brand/type of fluid?
I have read that using the drain only gets some of the fluid out and does not really count as a flush and that adding fluid is via the dipstick tube, any feed back on a simple way of doing this with out making a mess?
A/T light
sfd_656
- Vehicle: l400
- Growlerbearnz
- Vehicle: Delica P25W
Re: A/T light
Just a general observation: Old, worn out fluid is usually the cause of overheating*- the time to change it is before the overheating happens. How old was your transmission fluid? In any case, yes, it's definitely time to change it now.
I'm not hugely familiar with L400s so I'll leave the technical details to someone else.
*Unless you do a lot of heavy towing up steep mountains at top speed. That'll stress even brand new transmission fluid.)
sfd_656
- Vehicle: l400
Re: A/T light
Should I also be changing the filter at the same time? She has 80000km since purchasing from Amazing auto.
- Growlerbearnz
Re: A/T light
Since it's overheated it's probably a good idea, that way you can check for any nasty burnt bits in the filter.
