Found this on the ground after an oil change...
kurtiswilk
Vehicle: 97 L400 super exceed
Post by kurtiswilk »
hey guys
Did a routine oil change tonight and found this little diddy on the ground after bolting on the skid plate.
Not sure that it came from duncan as the calder pin and washer are all intact. as you see it is how i found it.
Figured i'd get another opinion.
found pin.jpg (25.24 KiB) Viewed 3450 times
Deli Duncan
97 L400 gen 2
Big-Bird
Vehicle: 96 PE8W Spacegear
Re: Found this on the ground after an oil change...
Post by Big-Bird »
That looks like the linkage pin for the front differential solenoid.
But did you find it assembled like that? If so I doubt it came off by itself.
johnghaley
Vehicle: 1997 Space Gear
Post by johnghaley »
If it was found assembled like it was in the photo then I wouldn't worry about it. We use pins like that on pivoting parts on air break systems, not that delica's have those.
John H
kurtiswilk
Thanks Guys,
Found exactly as pictured, figured it was not likely from the delica :)
Deli Duncan
97 L400 gen 2
Return to “L400 Technical”
