Interesting...sahdot wrote:The same inverter worked fine at idle and with engine off in my wife's Subaru with no screaming.
-jim
Noob Question
Re: Noob Question
- Artacoma
- Vehicle: 97 V6 LWB
Re: Noob Question
1000 watt Crappy tire oneWhat is the ampere rating for the inverter and where did you get it?
no screaming I have it wired directly to the batteries(x2) runs a 5 amp drill no problem, does not run a 10 amp shop vac, I was going to put it in the back inplace of the kareoke machine but I wanted the plug ins to be obvious so I don't forget em and use all the juice and it used up the blank space nice. The outlet is wired with a standard 110 plug that just plugs into the verter.I put it in bfore our road trip last summer to avoid buying 12 v plugs for all our toys.
Rik
97 Series 2 V6 LWB
97 Series 2 V6 LWB
Re: Noob Question
My plan was for the same inverter (1000watt from canadian tire) and to put it where the sound-stage was in the back, but I may wire a warning light up front to let me know if I leave it on...
- Schwa
- Vehicle: 1992 Delica Exceed
Re: Noob Question
I use an cheapo Cambodian Tire 450 watt inverter in my van and it doesn't scream too much, but the battery has to be in good shape, mine's not the greatest so just a few seconds of the heater fan running without the engine on will drop the battery too much, but will run my laptop for hours when fully charged.
dr_airtime
- Vehicle: a
Help ASAP - Where is fuel latch
Just spent 15 minutes looking for latch all around
The stupid little door hiding the fuel tank.
Lifted engine...somebody please describe
Well to me where the heck this thing is. I only have 1/8 tank and
Obviously a noobie. Not an idiot with cars too so I blame design
- Artacoma
Re: Noob Question
l300 I assume .......heehheee it took me couple minutes to find mine....to the left of the driverseat beside your hip is small lever that pops open a hatch right behind the passenger door.
Rik
97 Series 2 V6 LWB
97 Series 2 V6 LWB
kb&2dogs
- Vehicle: 89 BushBunny
Re: Noob Question
Did you really say that Rik???(by the way Marigold Service rocks! )
- Artacoma
Re: Noob Question
Hey that was 2008 and they did switch out the adjusters on my headlights for no money . A subsequent visit left me with some questionable advise so I never felt comfortable to go back.
....... I got a newsletter from them a couple years back that advertised auto service on one side and magic healing on the other side
... I should have kept it , it was good.
Rik
97 Series 2 V6 LWB
97 Series 2 V6 LWB
Re: Noob Question
Did you try the magic healing special?
kb&2dogs
Re: Noob Question
I got the same flyer, I wrote a very detailed message on the back of the envelope and returned to sender
