New Owner In Need of Guidance
Trinker
- Vehicle: L300
Hey guys, just bought an L300 that came with a couple of issues Im hoping to fix myself here asap. The first order of business in no Low Beams or running lights? Second order of business is some Gear oil running down the inside of my right hand rear wheel, looks like its spraying up a bit too... a seal of some sort?
92'L300 Chamonix - Fully camperized adventure rig
Re: New Owner In Need of Guidance
A couple of questions before any comments--- what year is your Delica?
-- is the leak oil or brake fluid?
Trinker
- Vehicle: L300
Its definitely gear oil, greasy and stinky..
Trinker
- Vehicle: L300
and its a 92 L300 (Chamonix)
Regarding the lamps, check your battery bay for fried connectors or burnt out fusible links. If you have fog lamps you can turn your running lamps (also known as marker lamps) on with that switch as the fogs are designed to run with the running lamps.
P.S.: '92 Chamonix rocks.
