Hello,
I've had my L400 for a month or so now and would like to give it a 2" lift for all the bush driving I do. My L400 has had the suspension upgraded at CCAutos with heavier duty springs. Is it worth lifting it with this work already done? Ive read it stiffens up the ride, but im not sure if that still holds true with these different springs? I find it a bit uncomfortable driving on a curvy highway at 100km/h, a bit of body roll in the corners. I would hate to increase the body roll.
Thanks for the help!
L400 Upgraded Suspension Lift Question?
- Vehicle: 1994 L400 LWB
- macro
- Vehicle: L400 "The Invader"
Re: L400 Upgraded Suspension Lift Question?
I have a 2" lift with wider tires, it doesn't roll any more than it did, that being said, it's a tall narrow van and some body roll is to be expected.
If the shocks are old and worn, replacing those will help.
-Mat
@delicacanada on Instagram
Thanks for the reply.
My suspension was replaced recently, I think the roll im feeling is normal for my van. Just worried that giving it a 2" lift with the heavier duty springs will make it worse. I thought I read something to that effect but I can't find the thread.
- macro
HD springs will help actually, they're stiffer. If you lifted with spacers and the original springs then you might notice more roll.
-Mat
I20
What was replaced, rear coil springs or front torsion bars or both? Were the shocks replaced too?
Check your invoice as Graham usually is very clear as to what work they've done.
TLWF
TLWF
Finally got around to calling CCautos, my springs were custom made to be very stiff and give the van a 1" to 1.5" lift in the back. Which is confusing to me since I measured the distance from the hub to the top of the wheel arch and the rear was only 0.5" higher than the front. The front measured 21.5" and the rear measured 22".
I've already gotten the spacer kit, can I still use it? Will it be to high now? The rear spacers are 2", the front are 1" with another inch gained from cranking the torsion bars.
Thanks, could really use so,e guidance with this.
How high do you want it? Keep lifting and replacing parts till you're happy or out of money.
- macro
You could re-index and crank your torsion bars (lots of threads on this) and see what you get out of it, then you'll be able to judge more accurately if you need the spacers in the back or not.islander20 wrote:Finally got around to calling CCautos, my springs were custom made to be very stiff and give the van a 1" to 1.5" lift in the back. Which is confusing to me since I measured the distance from the hub to the top of the wheel arch and the rear was only 0.5" higher than the front. The front measured 21.5" and the rear measured 22".
I am replacing my worn out rear springs and spacers with the CCA lift spring so hopefully I will be able to get rid of the spacers. Right now mine is riding like the back is fully loaded.
-Mat
