A few years ago I modified my dashboard just a bit in order to install a car PC. viewtopic.php?f=10&t=12731&p=98808
The car computer worked... as well as can be expected for something running Windows? I went through a motherboard a year (who knew they're not designed to be bounced around inside a vehicle? huh) until I gave in and bought an Android based double-DIN nav system.
Which meant more dashboard shenanigans. I love shenanigans.
Basically I've added a double-DIN mount hole at a reasonable height for use while driving, and extended the binnacle to encompass the new stereo. The hazard and rear wiper switches are moved lower, which makes room for (mismatched) boost and pyro gauges. I'd already moved the air vents when I first modified the dash.
I couldn't find brown vinyl in the correct grain, so ended up re-covering the dash pad with brown leather. Fancy.
Many pictures here: https://photos.app.goo.gl/LZ126ZDTmRcohLPQ6
Dashboard mod Mk2.
- Growlerbearnz
- Vehicle: Delica P25W
Dashboard mod Mk2.
- Modified dashboard
- Dash2sml.jpg (128.43 KiB) Viewed 3372 times
- Modified Dashboard2
- dash2asml.jpg (139.08 KiB) Viewed 3372 times
TieMyShoe
- Vehicle: L300
Re: Dashboard mod Mk2.
please do show how you did it.. the biggest peeve I have about my deli is having to reach across the van just to turn up the stereo...
- Growlerbearnz
The rest of the pictures are here: https://picasaweb.google.com/1171804076 ... jvXW9YSSdQ
Previous modifications (like moving the air vents etc) are in the earlier post
