Victor from Winnipeg.
L400 Gen II
Loving my Beast. Drive it primarily back and forth to work. Use it to tow a boat to and from the cottage as well as my utility trailer to the dump and back. Pulls like nothing is behind it!!! Plan to drive it to Whitefish Montana this spring.
ROLLCALL!!! - New and old members!
pinkfloyddewaal
- Vehicle: L400 Gen II
Re: ROLLCALL!!! - New and old members!
- New tires.jpg (83.81 KiB) Viewed 7010 times
Mephisto
- Vehicle: 90 5spDelica, 93 2.8 5speed SWB Paj
Matt in Langley/Vancouver BC
92 SWB Pajero: Parts truck, Auto, 2.5
93 SWB Pajero: Bush beast, manual, 2.8, locker, sliders, winch, 35s... It has been well used, even rolled and flopped a couple times.
90 L300: Manual, low roof, future pop top camper and world traveler
Yokohama
USA, 1990 L300 (P04W), 4G64, 4-spd auto (no manual option in USA).
Just finished new water pump (timing belt kit still has 40K miles left on it, so reused), and new Fel-Pro engine valve stems seals due to exhaust valve four seal going bad). Re-torqued head bolts. De-carbonized engine with Sea Foam though the vacuum port). Using Shell T6 oil.
Installed American Racing AR95 rims with 15 inch tires: installed montero wheel studs on stock hubs with 8mm spacers so tires would clear upper suspension arm outside edge (going to go down to 3mm hub-centric spacers, as the rims stick out too much).
Studying exhaust systems for maximum MPG.
Need 3.54 rear differential.
Converting A/C to R134a.
- aaronk
- Vehicle: Delica L400
Aaron - Yorkton, Saskatchewan
1995 Delica L400
Purchased from Rising Sun, made the road trip from Vancouver back home with some great detours and camping along the way. Look forward to more family roadtrips in the future! It's our daily driver and we are loving it! Hope to get a safari rack and ladder as well as to get on the WVO program in the spring!
1995 Delica L400
- FullSizeRender.jpg (117.55 KiB) Viewed 6918 times
- macro
- Vehicle: L400 "The Invader"
Looks great!! Nice rims!
-Mat
@delicacanada on Instagram
Dino
- Vehicle: 1994 Pajero 2800 LWB
I'm back
1994 V46 Pajero LWB 2.8L Diesel
Only 110,---kms on the clock, and plenty of undercoating to keep the rusties away!
In St. Catharines, Ontario. She's mainly just a DD runabout and winter beast. I've taken to riding my Honda for adventures, and I'm nearly finished an overhaul on my Suzuki which I ride for the thrills :P
One day I will take the Pajero out on a nice camping trip :P
