Inline Coolant heater.
P.Gaudreault
Vehicle: Mitsubishi Delica 1998 Chamonix
Post by P.Gaudreault »
Good morning,
I but a coolant heater yesterday at the canadian tire and I will installe it this week-end. Does some body have already installed one on there Delica?? If you have some trick that it's good to know, or picture to shear it could help me.
Here is the model:
http://answers.canadiantire.ca/answers/ ... stions.htm
Thank you!
Big-Bird
Vehicle: 96 PE8W Spacegear
Re: Inline Coolant heater.
Post by Big-Bird »
To work properly place it must be placed as low and as near to the lowest outlet on the engine as possible and the heater outlet needs to be connected as close as possible to a top inlet in the head, as directly as possible, otherwise it won't work well, or not at all.
There is a secondary heater and small diameter heater hoses for the passenger compartment that might lend themselves to this connection. I don't know of anyone on this forum who has installed this type of heater unit on an L400...at least not yet.
You could be first though!
P.Gaudreault
I feel like if I were the first man on the moon.. Lolll!!! I will let you know how its work when it gonna be installed.
Kamon
Vehicle: 2005 Sienna LE AWD
Post by Kamon »
There is one on my l400. Previous owner stated that it works incredibly well (since i havnt had my cold start issue solved i havnt driven it yet in this weather because it wont even come close to starting, so no personal experience) The nice part is the vents blowing warm air alot sooner inside the van!
Big-Bird
Post by Big-Bird »
Got some pics of where the unit is installed on your Delica?
P.Gaudreault
Does somebody know which size is the lower rad hose??? I tried to find the size on google but no success.. 1 1/4" - 1 1/2????
P.Gaudreault
Does somebody know at which temperature the thermostate open?? because I would like to installe a coolant heater like this instead.. Way easier to install..
http://www.ebay.com/itm/LOWER-COOLANT-R ... 1241649082
Check the shop manual in L400 Dedicated Category Reference Forum. I'd think it'll be under the Cooling Systems group.
Tojo
Post by Tojo »
35 mm hose inner diameter, or 1 3/8" if available. 1 1/2" too big.
IMG_20141117_125401 (2).jpg (81.59 KiB) Viewed 10038 times
P.Gaudreault
Thank you!!!!!!
I search so much on the internet without any result..
Thank you!!!!!
And I will look at this to..
Thank you!!!!!!
Kamon
Post by Kamon »
I can post a pic here in a bit big bird. I tried getting my van running first time this winter. Plugged it in for an hour although half hour would have been fine and it worked amazing. Started better than many times this summer. Then my father in law plugged it in to move the van and i guess it blew a coolant hose somewhere because the neighbor ran over telling us the van was on fire when in fact it was just super hot coolant dumping everywhere billowing steam from under the hood. So it works great!!! ................Just another problem to fix again. :cry: :cry:
P.Gaudreault
My coolant heater is not installed yet. I'll change the lower rad hose at the same time. My friend told me that a coolant heater is hard on your hose. Good luck with your van.
P.Gaudreault
Coolant heater is installed and look to work great. I'll see tomorow morning how my Deli start.
Tojo
Post by Tojo »
Can you post pictures of your installation? I was thinking of doing the same thing. I was having trouble starting a couple of weeks ago in the colder temperatures. I have an oil pan heater, but no coolant heater.
P.Gaudreault
I'll do it no problem.
Return to “L400 Technical”
