coolant leak
verlioka
- Vehicle: delica
coolant leak
loosing coolant, drips quite fast, one drop per second. tried to look for leaking spot, looks like it comes from under cranking shaft, at least after wiping coolant from engine this place gets wet first and then down towards alternator, on the oil filter, and makes pool on the ground, any idea what should I look at first? I have Delica L400 1997 TD 2.8
- thedjjack
- Vehicle: 1989 L300 HITOP!!
Re: coolant leak
water pump has a hole to let coolant out when seal blown.... replace water pump... good time to do coolant hose, thermostat, and rad flush...
