uh oh… starter? fuse? help?
				westbound nate
- Vehicle: 91 mitubishi delica
https://www.youtube.com/watch?v=FCRu0jU ... e=youtu.be
any ideas why this is happening?
the battery is fine, the glow plugs click as they should… starter?
there have been a few times where it's done this and then fired up fine on the second try, but now nothing at all.
any help would be appreciated, you all are awesome.
Time Travellers Union
"the future ain't what it used to be"
				westbound nate
Re: uh oh… starter? fuse? help?
I've cleaned the battery terminals, tried jumping it off a running car… no change.  i don't want to have it towed to a mechanic just to find out it was something silly and common/easy to fix.
- Firesong
Check your connection to the starter. Hit it with a hammer. I believe there was a thread not that long ago that had the same symptoms. I think it was the fuse /wire off the battery.
						- Firesong
				Overlanderjay
- Vehicle: Ford E350 Econodeli powerveg
Check the fusable link wire , when you open the battery compartment, looking towards the back of the compartment (back of vehicle), the fuesable link is on the rear left . the fuseable link wire is about four inches long with white plastic connectors, check the connectors they tend to burn out.
							"Electrickery Technition"
						- dennis_lambert
My starter was intermittently not working a while back....
The culprit was dirt and oil cramed in a loose spade connector on the starter.Single control wire to the solonoid.Cleaned it and crimped the connector a bit and problem went away.....
- TRUTHautomotive
- Vehicle: Delica L400 High Roof
+1 for this, I had some melt happening on these connectors, the melted plastic on the contact surfaces created too much resistance in the circuit and I had a no start scenario identical to yours.Overlanderjay wrote:Check the fusable link wire , when you open the battery compartment, looking towards the back of the compartment (back of vehicle), the fuesable link is on the rear left . the fuseable link wire is about four inches long with white plastic connectors, check the connectors they tend to burn out.
I removed the connectors used a screw driver to scratch the plastic off the contacts, reconnected and she fired up as usual. Going to replace the connectors as soon as I get a chance.
TRUTH Automotive Services
General and JDM Maintenance in Calgary AB
