JSweet
Vehicle: L400 Super Exceed
Post by JSweet »
FalcoColumbarius wrote:
JSweet wrote:Anyone had any luck restoring the wind/rain deflectors? Mine are less than transparent.
Auto Glym Vinyl & Rubber Care, you can get it at Canadian Tire for around $15. It restores the oils into the vinyl/plastic. Depending on how faded or blued the eaves are you may require two or three applications.
When you use a heat gun it draws the oil from deeper in the plastic closer to the surface, which makes it look darker. The drawback to this is the oil at the surface tends to evaporate, which is why it goes faded. The more oils leaving the vinyl, the more likely it will crack over time.
Perfect, I'd heard that about the heat gun trick, I was researching which products to use on it, I'll grab some at Canadian tire for sure.
Firesong
Post by Firesong »
Decided to do something productive today! -30 Celsius = winter front for the Delica.
Have some left over puckboard and zip ties... Needed decals too...
Firesong
Post by Firesong »
And for those that will ask. No one steals pink extension cords :)
RadarGrrl
Member's Photo Album: http://www.delica.ca/Photos/index.php?cat=22564
Vehicle: 1998 L400 Chamonix
Post by RadarGrrl »
Why do you think nobody swipes pink extension cords?
What a lovely Chamonix. What's the rest of it look like?
It's not just a van, it's an entire subculture!
Firesong
Post by Firesong »
As for stealing cords I think it's mainly guys who steal them. And those cool thieves wouldn't be caught dead in pink. Not tough enuf!
To see the rest of the Delica goto the member trips and look for Rocky Mountain house trip. Some pics there.
RadarGrrl
Post by RadarGrrl »
This is very true. For some reason, pink is such a threat to the male ego. I have no idea why.
Your Delica looks vaguely familiar,somehow...
Shaun Van Ramen
Vehicle: '91 Exceed
Post by Shaun Van Ramen »
I worked on a big construction project and the parent Co. we worked for was from Texas. We were all surprised when the good 'ol boys had us buy pink X-chords. Same reason.
Today I made a set of Door Cosies. THey are like a tea cozy but made of faux sheepskin (to go with the ShauntheSheep motif) and attache to the front doors to keep the chill off.
Now I need to experience some sub-zero temps again to see if they actually do any good. But they are kinda cute.
Door cosey2.jpg (20.24 KiB) Viewed 10414 times
door cosey1.jpg (24.16 KiB) Viewed 10414 times
BAHahahahahahaha
del400
Vehicle: Delica L400
Post by del400 »
New Snorkel Baby!
Decided to go with the "home made" kit. Cost me $90 and 2 hours of hanging out with my brother.
A
del400
Post by del400 »
Also Changed the fuel filter (took 40 minutes). Real easy.
A
Erich
Vehicle: Mitsubishi Delica Exceed 1987
Post by Erich »
Pink extension cords? You could call them fuchsia! I had a fuchsia racing bike, a Mercier. fuchsia was the Mercia racing color. No one wanted to steal it.
nxski
Post by nxski »
I actually did this 2 days ago...
My front right calliper seized less than a year after doing the dual piston upgrade. Turns out, one of the 2 pistons was stuck, and luckily, the right side I had done by a shop, because the right one I had ordered from Rockauto was defective (wrong thread). Paying double for it at the time sucked, but being able to take it back and have it replaced within a couple hours and warrantied was very nice. 8-)
Beausoleil74
Vehicle: 1996 Space gear super exPajero-mini
Post by Beausoleil74 »
The replacement for the center console finally arrived and was installed at future shop. Who agreed to pay half for shattering the (already cracked) original. Soon as the snow goes it's time for a spring clean up after a long Alberta winter. I already noticed a touch of rust on the front chrome bullbar. any tips out there?
1995 Pajero-mini turbo
1998 Minica Toppo Town Bee
Changed the oil and the rear LSDiff oil. First time doing the diff and the gear oil smells like a dirty latrine. As I'm using LiquiMoly for the motor I thought I'd try the LiquiMoly LSD gear oil.
eastywesty
Vehicle: '92 L300 Exceed Crystal Lite
Post by eastywesty »
I put a 110 amp alternator in my 92 L300.
My alternator went a few weeks ago. Since I have a regular exceed that had been winterized (dual batteries, oil pan heater, block heater, trickle charger) but still had the original 75 amp alternator I was torn between getting mine rebuilt or getting a bigger one. I took my broken one to a place here in Grande Prairie to see if it could be rebuilt and they said they couldn't. I priced out some new, used, and rebuilt ones out of Vancouver. I found a 110 amp one of korean make for a reasonable price but I was nervous to do a straight swap as I found a topic either here or on the UK forum saying that I would need to install higher gauge wire and I am no electrician. But I did it any way! I put it in last weekend and have been driving all week, no fires, batteries are still good, I think I am in the clear.
P.S. I am due for an oil change soon and was contemplating doing it with the alternator out, but it was too cold out. Now I have no idea how that filter is going to squeeze out of there.
-jarrett
eastywesty wrote:...
-jarrett
I get at the oil filter from under and behind, where the exhaust manifold connects to the pipe. Once I've drained the pan I reach up from there and unscrew the filter. It really helps if you have two wrists in each arm , like Edwin at CVI does (that guy is amazing, he has all these extra joints in his body ~ he just... crawls into and becomes part of the vehicle and fixes everything because he's... just amazing). Not to worry, for basic mortals like you and I ~ it can be done with only one wrist. It helps if you have those sabre toothed pliers for undoing the filter.
