Needing a rim that fits a 31 -10.50 - 16 for my Delica..
jelley911
- Vehicle: 91 L300 Delica Super Exceed Lifted.
So i have my Delica for about 4 months now...and loving it. Then my daughter bends a Rim, so now i am looking for a 31 inch rim. anyone have one? or where i can get one? I am waiting to hear back from CCA if they have one but no luck in the world yet..Help!
- Big-Bird
- Vehicle: 96 PE8W Spacegear
Re: Needing a 31 inch Rim for my Delica..
That's not possible..... 31" rim is big rig size, not Delica size
Your rim is either a 15" or 16" diameter.
Width will be 6", 7" or 8"
The rim dimensions are stamped inside the rim's center or bolt pattern area?
What size tire are you using?
235-75-15
30-9.50-15
31-10.50-15
Or something in the 16" range?
235-75-15
30-9.50-15
31-10.50-15
jelley911
Sorry my bad, yes i need rim that fits a 31-10.50-15. otherwise i have to have my lift kit dropped and new rims and tires.
- Mr. Flibble
If you are running the standard rim size, then I believe any Toyota 4Runner rim should work just fine. It does depend on your tire, but many L300's have Toyota rims on them.
jelley911
Re: Needing a rim that fits a 31 -10.50 - 16 for my Delica
I was told that it is an offset rim and that i cannot put a standard rim on it...any suggestions?
- Mr. Flibble
I am not sure I understand what you are saying here... are you saying the rims won't match?jelley911 wrote:I was told that it is an offset rim and that i cannot put a standard rim on it...any suggestions?
If you can't get a matching rim, but the tires are compatible, why not replace all four rims? Steel Toyota rims are super cheap used.
TieMyShoe
- Vehicle: L300
I am confused... can you please reword this a bit more specifically.. "it" is rather vague...jelley911 wrote:I was told that it (the stock rim? your current rims?) is an offset rim and that i cannot put a standard rim on it (the van?)...any suggestions?
Also.. when you say rim... are referring to rim or tire? I feel like you are calling both items a rim.
jelley911
Sorry for the confusion...
I have 31-10.50-R15 tires on a set of rims that have a 6 inch offset. My Delica is lifted about 2" and i am having a hard time finding a rim to replace the on that was damaged. does that make more sense?
John
John
Why don't you post a picture of one of your good wheels so people know what it looks like?
