So when in 4 wheel drive with the delica there is no diff lock? In my bj70 I installed front and rear arb lockers.....goes anywhere. Can someone explain the delica setup.
Jordan
Diff lock
Klecko
- Vehicle: 1996 Delica l300 Active World
yojimbo
Re: Diff lock
Difflock on a modern 4x4 means the center diff is locked, providing equal power front and rear. They may also have front and rear diff locks as a separate thing. The L300 has no center diff, only the transfer box, which splits the power front and rear in 4x4 mode, so it's functionally the same as having a locked center diff.
If you want to fit front and rear lockers that another subject.
1994 L300 Jasper
1986 Scimitar 1.8Ti
1986 Scimitar 1.8Ti
Klecko
Re: Diff lock
Thanks!
