Best (Ply)wood for bed costruction
- Super Exceeded
- Vehicle: 1993 L300S
I am going to start building the sleeping compartment in stretch. Does anyone have any suggestions on what it the best material to use. THX
Arnold
Arnold
- gezzza
- Vehicle: 92 exceed
Re: Best (Ply)wood for bed costruction
I did mine out of eco board. Its similar to white board ,what they use for kitchens but it is half the weight and waterproof. My friend is a kitchen/cabinet maker so it was recommended and built by him.
- Super Exceeded
THX mate.
Should have posted on your forum down there!!! :)
- thedjjack
- Vehicle: 1989 L300 HITOP!!
Windsor Plywood has nice Birch Plywood for a ok price...
drawings of the plans? What are the ideas?
- Super Exceeded
Plans shlams.... Just gunna wing it. It will be a pullout kitchen from under the bed the hinges into an L shape. Hope to start next week when airshow season is over...
- thedjjack
I like my kitchen inside myself as the bugs are outside depending on where you go...
I am ok with no plans....I seem to roll that way....
Get that 350 in there already and light them up :)
Let me know if you fly north vancouver island...
- Super Exceeded
350is at the shop, Tranny and transfer case currently in Calgary. Truck "should" head there shortly.
- macro
- Vehicle: L400 "The Invader"
For my actual sleeping platform I used 3/4" ply, you can have less supports underneath that way.
-Mat
@delicacanada on Instagram
- Artacoma
- Vehicle: 97 V6 LWB
Baltic birch plywood , it comes in 5'x5' sheets , has very thin consistent veneers of hardwood and no voids, so you can use thinner sheets.
Rik
97 Series 2 V6 LWB
97 Series 2 V6 LWB
- macro
Where do you get that? Sounds perfect for some other projects.Artacoma wrote:Baltic birch plywood , it comes in 5'x5' sheets , has very thin consistent veneers of hardwood and no voids, so you can use thinner sheets.
-Mat
- Artacoma
Most lumber yards carry it around here, if you are in a Rona/Home Despot dominated region try looking under hardwoods in the yellow pages. Windsor Plywood carries it as well. A 12 mm sheet should run around $45.
The 5' size is nice for spanning across the van without joins.
- photo1.JPG (110.7 KiB) Viewed 7445 times
Rik
97 Series 2 V6 LWB
97 Series 2 V6 LWB
