backflush heater core
				strada-caster
- Vehicle: Mitsubishi Strada 1992
I was just trying to backflush my heater core and got nowhere with it.   passing water in the normal flow direction was no problem, but all I could do backwards was pressurize the line.  Is there a valve somewhere behind the firewall?  its pretty cramped in there and don't really want to rip it apart as I have heat, just wanted to clean it out a little.
						- Strada 92
- Vehicle: Mitsubishi Delica L400 1995
Re: backflush heater core
Yes there is a valve that control temperature of the HVAC.Cold=cut the flow of coolant thru the core..Hot=coolant is flowing thru the heater core.
That valve is behind the top of the dash,over the gas pedal.
Mitsubishi L400 Spacegear
Mitsubishi I-MiEV 2012
