...if they are necessary for inspection/registration?
also, what else is an issue, i.e. daytime running lights etc and where do you guys have them solved?
Thanks a lot
Where should I get the headlights...
mokele
- Vehicle: Mitsubishi Delica Spacegear
Re: Where should I get the headlights...
is it a series 1 or 2? 2's don't need new headlights but the 1's do.
- Tojo
DRL module: http://ccautos.ca/parts/mitsubishi-28/drl-module.html
Heavy duty DRL: http://ccautos.ca/parts/mitsubishi-28/h ... odule.html
Headlights: http://ccautos.ca/parts/mitsubishi-28/l ... p-dot.html
You can also get this stuff from Amazing Auto's, Rising Sun and Rocky Mountain imports among other places.
You will also need side markers. I got mine from CBS truck parts in Burnaby as they have a bigger selection, but it's cheaper from Crappy Tire. I also had to replace my radiator overflow bottle as it was cracked. Then of course there is DOT stamped tires, brake inspection, etc etc...
