There is diesel smell on the passenger side of the vehicle. I think I have a leak. No spots on the ground/snow though.
I am going to crawl under today and have a look at the engine but if anyone has a suggestion of who the most likely spots might be would be helpful. I don't have much automotive knowledge here. Waiting for my manual to arrive in the post.
Thanks,
Kuan
I smell Diesel
mitch
mitch
- 39Ronin
Its common for the top seal where the top 1/3 of the pumps meets the bottom. Its attached by 4 allen bolts. If you check for leaks you probably won't see one during idle, so use your hand throttle (some people think this is a choke but its not) set it with revs high... say 3000 rpms that whay the pump will be under more pressure and expose a leak.
Check out this:
http://www.pocuk.com/forums/viewtopic.php?t=22563
Check out this:
- Kuan
- Vehicle: 94' L400 SWB
Hey guys thanks for the tips.
I'll rev it up tomorrow and check it out.
Thanks for the link, good info on the repair.
Does anyone know where to get the O-rings for replacement? Anyone have sizes and/or part #s.
Oh, and can anyone one recommend a good diesel mechanic between Nanaimo and Victoria with some experience on these Beasts?
