so my van sat for 3 months without running, today i just replaced the lifters(pulled the rocker assembly all the way off) got it all back together and i don't have spark, i did a quick check over all the connections i could find... i couldn't find the main fuse box juts the one for the accessories?
any ideas or theories would be appreciated
thanks
EDIT: i'm getting 0-2 volts at the dizzy end of the coil wire
EDIT2: getting 12v on the coil output and on the two wires going into it but when cranking those 2 wire drop to a steady .7-.76
EDIT problem solved, the plug on the back of the dizzy was slightly ajar
FIXED: '87 g64b lost spark?
minimotos95
- Vehicle: 1987 mitsubishi wagon
1987 US wagon base model g64b
- Strada 92
- Vehicle: Mitsubishi Delica L400 1995
Re: '87 g64b lost spark?
Maybe the ignition module?It is in the distributor.Distributor from dodge ram 50 1990-1993(4g64),Mitsu mighty max or Hyundai Sonata 2.4 1989-1991(g4cs) fits.
Mitsubishi L400 Spacegear
Mitsubishi I-MiEV 2012
minimotos95
i'll check it out tomorrow after cleaning all those cobwebs from the intake side of the engine bay, that's good to know as i have a 91 mighty max sitting out front with a blown waterpump i can borrow parts from to diagnose.
there should be 20kv coming out of the coil? so something is causing the coil to let power flow right through it without amplifying
If it's the 3.0L, there was a recall on the engine because the crankshaft pulley bolt would shear off. I had it happen on mine and it ruined the engine. Sorry for the side-track, but I figured you might want to know if you didn't already.minimotos95 wrote:I have a 91 mighty max sitting out front with a blown waterpump i can borrow parts from to diagnose.
