I'm in the same boat, I have some HD springs and HD torsion bars (hopefully) on order right now, and then I was going to scour the forum for some Pro Comp or Bilstein part numbers for the struts. I'm also going to send Jesse an email and hopefully get some ball joint and brake bias spacers and I believe that should about cover the whole lift. Can anyone recommend what bushings to do while everything is apart?Deli-East wrote:Hi,
I am interested in purchasing a suspension lift kit for my 1994 L400 Spacegear, SWB, Diesel.
A Canadian vendor would be preferable but not essential.
Lift Kit wanted....
- macro
- Vehicle: L400 "The Invader"
Re: Lift Kit wanted....
-Mat
@delicacanada on Instagram
- macro
Email sent!jessef wrote:Hey guys
I'm not getting emails via the forum for some reason. Not even in my junk mail folder.
Feel free to shoot me an email direct jfarsang @ gmail.com
-Mat
Hey Matmacro wrote:I'm in the same boat, I have some HD springs and HD torsion bars (hopefully) on order right now, and then I was going to scour the forum for some Pro Comp or Bilstein part numbers for the struts. I'm also going to send Jesse an email and hopefully get some ball joint and brake bias spacers and I believe that should about cover the whole lift. Can anyone recommend what bushings to do while everything is apart?Deli-East wrote:Hi,
Depending on the condition of your front upper/lower balljoints, you may consider replacing them during the install as they will be easily accessible. Same goes with the front stabilizer end links and the rear sway bar end link bushings.
- Vehicle: Delica L400
OK. I have very minimal time here. I got a hold of Jesses Lift kit but still need the shocks.
Can't wait long as my time is almost non existent right now.
Anyone know which shocks to get for the 2" lift either procomp or better bilstein shocks. Part number where anything
All front - 915510 Promcomp
Non-ECS rear - 925509 (eye bottom / eye top)
ECS rear - 925510 (eye bottom / pin top)
Order poly bushings to replace the stock rubber one's # PV2028 (5/8" eyelet)
Maybe i should wait until you get yours...
Seems i'll spend more time looking.
CVI can't find any either.
I hate being cramped for time.
