Are my rotors toast?
lettereleven
Vehicle: L400 Super Exceed
Post by lettereleven »
At what point do you know you need to replace a rotor?
No shuddering under braking, so that's good.
When I rotated my tires, I saw that there were big grooves on the rear rotor.
I have to get new front pads and calipers, and I wondered if I need to get rear too.
Yay, more money on the van.
Thanks for you help
Jamie
Re: Are my rotors toast?
They're not toast, they're round. :-D
Okay, seriously though. If you've got grooves on the rotors, it'll just chew up new pads (look for grooves on the old pads to match). Shuddering comes from a warped rotor and if you don't have that then they're not warped.
A lot of brake shops will tell you for free if you need new parts - drop in to one of those.
lettereleven
Thanks Paul!
I'll just pop by and have someone have a look.
Got all the bits for the front, and I am looking forward to the project.
thelazygreenfox
Post by thelazygreenfox »
LE
Butch at CVI turned my rotors. Cheap too.
TLGF
CREGAN
Post by CREGAN »
Never realized it was the rear. Yeah you can get them turned, but the rear are just Montero rotors you can get anywhere so I would just replace them. Then you know your starting point, and they are not horribly priced because they are not Delica specific.
Craig
Return to “L400 Technical”
