 Driving from Revelstoke down to Shelter bay on the way to hot springs in Nakusp,suddenly on the dashboard not only D was iluminated  but also N and L and in lower righthand corner the A/T temperature was lit. So I stopped, let her idle a bit to see if it would go away but no, it stayed. I checked the color and quantity of ATF and it did seem to be a OK
  Driving from Revelstoke down to Shelter bay on the way to hot springs in Nakusp,suddenly on the dashboard not only D was iluminated  but also N and L and in lower righthand corner the A/T temperature was lit. So I stopped, let her idle a bit to see if it would go away but no, it stayed. I checked the color and quantity of ATF and it did seem to be a OKSince I was in the middle of "nowhere"{sorry, guys in the Kootneys} I decided to see if I can nurse her at least to Vernon,which I did,checked everything again and all seem to be good so I kept going no problem through Kelowna,over the 1700+ pass to Merritt again no issues,went through Hope,all good.
Now I'm at Starbucks in Chilliwack getting ready for the last leg home.
I wonder if anyone had experienced something similar?
By the way, on my way out last Sunday, before the Langley exit I was overtaken by "Gumdrop" I waved but I guess it was not seen.
 Made it home OK.
 Made it home OK.
