headlights turning back on by themselves!!!
ruggles
- Vehicle: 94 L400 space gear
I came outside tonight to find my headlights were on but the switch was off! i had to turn the csr on and then shut it off and turn the switch on and off again. They turned off for a while csme on the off and now twy are stuck on. wtf is causing this. Which fuse or relay is it for the headlights or drls? Please help!
- Artacoma
- Vehicle: 97 V6 LWB
Re: headlights turning back on by themselves!!!
My van (from cc auto) has the drl unit under the hood between the fuse panel and the drivers side headlight.
My old van had headlight issues like that when the drl unit burnt out, it melted to the consistency of a soft marshmallow. It was a black cube about 35mm square.
I replaced it with a heavy duty version and all was good.
I think CC autoes has a pic of the heavy duty one their parts page, it has a ribbed metal case.
Here's a pic of the one in my new van
- drl.JPG (123.01 KiB) Viewed 5105 times
Rik
97 Series 2 V6 LWB
97 Series 2 V6 LWB
ruggles
Awesome thanks man I'll take a look this afternoon and report back. Hopefully thats all it is!
ruggles
There isnt a drl module that i can see. Any chance its wiring directly to my ignition switch amd something is messed up there? any wiring gurus out there? Ill have to pull the hradlight relay during the day till i figure this out!Artacoma wrote:My van (from cc auto) has the drl unit under the hood between the fuse panel and the drivers side headlight.
ruggles
Fixed thanks to claude. It was a relay put in aftermarket hanging upside down under the fuse box full of water. Ill get a replacement and move the relay to a better location. Woo hoo
blevesque@shaw.ca
- Vehicle: 96 l400 super exceed
Thanks to this thread I was able to trace and resolve the same problem. My DRL relay was mounted under the hood and got wet during a heavy rainfall causing the headlights to stay on. Simple fix really, just disconnected the relay, pried the cover off, let it sit in the sun for an hour to dry, put it back together and voila headlights go off and on as they should. I also strapped the relay out of the way so it wouldn't get wet again. Thanks everyone!
- MardyDelica
hi, those DRl usually don't work good for all this L300 and L400.
I did try and install heavy duty or light duty those type of relay, for the past 5 yrs now from grote one , Canadian tire or diff type of drl.
for some reason it wont work:
since them I just used the LED day time running light and so far for the past 3 yrs not a single problem with there electrical problem.
only to replace the led led when it burnout. as the led only used 2w electric that saves your alternator lifespan than the full voltage12V output DRL.
fix many of those full voltage 12V DRL and replace with LED DRL with customer feedback they happy and less headache.
will never go back to those grote DRL again as its not compatible for this Delica. it burn sometime electrical problem component and other. result is expensive and unhappy customer.
hope this help
cheers;
hope this help
cheers;
