transmission swap...from one van to another...?
rainypotato
Vehicle: L300 starwagon 4D56T
Post by rainypotato »
bad times with the deli :-(
what to I look for to be certain that the transmission on the parts deli at a friends house will work to swap?
thanks!
rainypotato
Re: transmission change
L300, automatic
joshh
Vehicle: 1992 mitsubishi delica starwagon
Re: transmission swap...from one van to another...?
Post by joshh »
as far as I know the transmissions are all the same 89 - 97 I believe. it should drop right in (I know, easier said than done). however I would call one of the reputable shops and ask the mechanics, coombs is always a trusted source for myself for these inquiries.
good luck!
rainypotato
Re: transmission swap...MODULE problem
new (used) tranny dropped right in, so nice to have something go 97% smooth...
now I have an issue with the module that tells the dashlights, reverse lights, and silly reverse beeping what gears are being used...
the newly installed tranny had that part all seized up and it quickly broke. Now I drive with the dashlight in P, no reverse lights, etc.
My old tranny's module worked fine, but removing it is proving to be a real problem, hard to manage the 'inner ram', Ifear breaking it...
Any tricks out there???
As well, is it worth it to strip my old tranny of all the little things?
Thanks, Jen
rainypotato
It still hasn't come free...
Tojo
Post by Tojo »
Pictures?
rainypotato
Photos from this link to the 'the good part' is just that.
I am trying to free it (soak in wd40, a mix of atf/acetone and fluid film) with light prying action and tapping on the bolt to get things vibrating off.
http://www.flickr.com/photos/rainypotato
rainypotato
pics
the neutral safety switch, seized beyond belief and rather brittle
BeV
BeV
yup, I pounded that rod from the other side...oops?
view to the bell housing
Rattlenbang
Vehicle: delica
Post by Rattlenbang »
Oh, man, I feel your pain. That's the kind of stuff that gives grey hairs and high distillery stock prices. Can you get a small puller on it?
