26mm Sandwich Adapter is here - along with other bits.
Mr. Flibble
Post by Mr. Flibble »
Here is the Adapter:
The Adapter
The Adapter
The exploded view:
Exploded view of the parts.
The engine Side:
The seal that goes against the engine side. Note the side ports I requested to be drilled in are the brass bolts.
The seals on each part:
A view of the seals on each part. Note that for assembly purposes, the Aluminum engine part is upside down relative to the blue anodized oil filter relocation part.
The middle piece just "drops" in the engine part. It appears to be steel. It is the part that screws onto the engine, but it does not directly mount or screw into the large aluminum block itself. It just sits there freely. It is the attachment point to the engine itself that will hold the whole thing on, which is why it is probably steel.
The steel middle
The steel middle
Mr. Flibble
Re: 26mm Sandwich Adapter is here - along with other bits.
Here is the remote filter:
Remote Filter
Remote Filter
Here you can see the three mounting spots to hold the remote filter:
Mounting triangle
Mounting triangle
The working bits:
The working end
The working end
Closeup:
A closeup
A closeup
Side and Plugs:
Side and included plugs
Unfortunately, the threads don't match!!!
Non matching threads?!?!?
Mr. Flibble
If anyone can offer me any advice as to why the filters don't match the threads I would really appreciate the help.
The specs on those filters say "1-16", which is exactly what the remote filter says! I am guessing that the actual threads don't match - but I can't figure out why if they have the same size rating from everything I can see.
I will also add, that while the Jackmaster part looks much less shiny than the remote dual filter shown here, it is better made from a machining perspective.
The Jackmaster has some scratches and is not brilliantly shiny - but it has no sharp edges and is machined properly where it counts. This remote filter has been flaking off multiple sharp bits of aluminum from sections where it was drilled and tapped. I am going to have to spend some time filing down many parts of the remote filter mount.
The Jackmaster is otherwise ready to go.
Now I need to figure out how to get some filters attached though. Otherwise I can't use this thing at all. :-( :-( :-(
Here are the specs on the filters I bought:
Fram dimensions:
FRAM PH3976A
Product I.D. : 1-16 Th'd
Product O.D. : 3.66"
Product Height. : 6.91"
Gasket Usage. : Base
Gasket I.D. : 2.42"
Gasket O.D. : 2.8"
Gasket Thickness : .25"
Relief Valve PSI : NONE
Anti-Drain Valve :
And from the product page of the filter mount:
http://shop.perma-cool.com/1226-Dual-Fi ... d-1226.htm
Duel Remote Oil Filter Mount
1/2" NPT ports L & R, 1"-16 thread
Mount an oil, lube, or fuel filter in a more convenient location. Fully illustrated instructions included. Mount is designed to use filters with 1"-16 threads such as Fram® PH10890 or equivalent.
Item #: 1226
nxski
Post by nxski »
Looks pretty much the same as my adapter, but I've never had a problem getting the filters to work. :shock:
psilosin
Vehicle: L400
Post by psilosin »
I'd just take the adapter into the Washington equivalent of Canadian Tire (Fred Meyer?) and try screwing on some different filters to see whats what in the butt.
almac
Vehicle: '91 Delica "Tessen"
Post by almac »
i would be interested in the engine block adapter(i already have a remote filter mount).
what is the price point on this part? :?
al
Mr. Flibble
almac wrote:i would be interested in the engine block adapter(i already have a remote filter mount).
Here is the total I paid from Jackmaster:
Au$108 - Delica sandwich
Au$56 - remote sender unit to suit.
$Au$62 - Registered Air post
Au$226 - Total
All in all, a fair deal for the parts I think. He can also change what parts are drilled/attached. I got mine exactly as requested with 3 NPT ports drilled and the threaded oil pipe.
Mr. Flibble
So I got myself a set of thread measuring tools. Looks like the double oil filter is 1"-12 thread, not 1"-16 thread. Which would explain why my filters don't fit!
I will be contacting Perma Cool about the threaded nipples being the wrong size.
Mr. Flibble
Wow, so I contacted Perma-Cool about the mis-sized dual filter and they were incredibly responsive!
Seems that they had a small batch that had 1-12 nipples instead of the 1-16, so they got out the door wrong. They apologized profusely and quick shipped me a entire replacement piece! Not just the mis-sized nipples, but an entire new dual filter setup with the proper sized nipples!
Colour me impressed! Everyone makes mistakes, but for a company to admit them and immediately overnight ship a replacement at no cost? That is a good company.
(CIBC, I am looking at you as an example of a bad company and your moronic policy's on Self-Directed RRSPs......)
Mr. Flibble
New adapter arrived via UPS!
Victory is mine!
So, if anyone out there wants to buy a dual remote filter with 1"-12 threaded nipples on it, let me know!
almac
Post by almac »
system looks good, EXCEPT for the FRAM filters.
i have had 3 filters bulge on me(their bypass valves fail), and now avoid them like the plague.
if i were you, to avoid risk, i'd goto a filter like WIX or Hastings... IMO.
al
psilosin
Vehicle: L400
Post by psilosin »
So what is the design of the dual filter? Are both full flow...and if so does 1/2 the incoming volume go to filter1 the rest to filter2, or does all go to filter1 first and then all to filter2 after?
Mr. Flibble
almac wrote:system looks good, EXCEPT for the FRAM filters.
I had considered that - they had some serious quality control issues in recent years. The upside is that they admitted that they were at fault and took steps to ensure those problems don't occur again. I could go with another brand, but these filters cost $6.00 each and are easy to find. (I could go with another manufacturer in a pinch as these are Cummin's standard sizes.
Also being added as part of this project are my gauges. I will be installing my combo boost/egt/temp gauge and a dual oil temp/pressure gauge. If the filter fails the new gauge will let me know, and I will also have more oil to deal with the problem. I actually had a filter failure with a regular Delia filter - but that was because the guys at Walmart did not check to remove the oil seal that was stuck to the engine when I got them to change it. (Not happy about that!)
psilosin wrote:So what is the design of the dual filter? Are both full flow...and if so does 1/2 the incoming volume go to filter1 the rest to filter2, or does all go to filter1 first and then all to filter2 after?
They are both full flow. Half goes into one, half into the other and then back into the engine. It is possible with this sort of setup to install a bypass filter like a Amsoil one that restricts the flow a bit more, thus more of the flow would go through the other filter. But in this case, this is a $12 setup that increases the oil volume - and thus the cooling. My bypass filter will come out of the sandwich portion of the Jackmaster filter and go to my Frantz. I thought about using a centrifuge, but I already own the frantz, so that makes sense to use it.
If you look at the pictures of the dual filter closely, you will see some arrows on top. Those show the direction of the oil. One in, one out. The reason you can move the plugs around is that you may want the pipes to come in and out on one side, or go "straight through" for ease of mounting options. You could have two pipes in, and two pipes out, for even more volume I guess as well.
macro
Vehicle: L400 "The Invader"
Post by macro »
This might be a silly question... Is the remote filter just for ease of access? Or is there another reason?
Mr. Flibble
macro wrote:This might be a silly question... Is the remote filter just for ease of access? Or is there another reason?
Ease of access can be one reason. Although this depends on where I put the remote filters!
Moving the filter allows you to move it away from the bottom of the engine where it is at great risk of getting whacked by rocks or something pushing in the bash plate. With the length of the L400 oil filter this is a pretty big risk. Since you are relocating it, you can use 2 filters as I have here. This divides the oil flow into 1/2 for each filter. This allows for better flow. This also increases the total volume of the oil in the engine, improving cooling and longevity. Another added bonus is that the remote filter that you use need not match the Mitsubishi format filter. Meaning, you can use other brands of filters that do the same job. In this case I am able to use inexpensive Cummings engine oil filters. These filters are also much easier to find than the standard Mitsubishi one.
