26mm Sandwich Adapter - Simplify your Bypass Filter Install
nxski
Re: 26mm Sandwich Adapter - Simplify your Bypass Filter Inst
Post by nxski »
I used the Cummins filters with my bypass system when I first installed it but was told they would need to be changed at 10,000k instead of 20,000km if you use the Amsoil ones!?
bionic
Vehicle: 92 delica exceed
Post by bionic »
I ran the Amsoil dual bypass system, not just an adapter. This means you have a primary filter and a secondary filter. (2 total) The primary was the mopar filter...typical truck diesel filter only slightly larger for a cummins motor, good for 5-10k, the secondary was the Amsoil unit which had almost twice the capacity, good for 15-25k and five times the filtration. (and cost) This broke down to replacing the secondary filter every 4-5 oil changes. I ran it a little longer. Added over a quart to the stock oil capacity.
Mr. Flibble
Post by Mr. Flibble »
If one were to run this kit and relocate the oil filter you could use just about any oil filter in place of the standard Fuso one which is quite expensive. Does anyone have a suggestion for inexpensive replacement filters that are just as good and about the same size? The Oz forum has a few filters, but those ones that they talk about are not available in North America from what I can see.
nxski
Post by nxski »
Basically, you'll just need to go to an autoparts store and size up their cheapest filters. The Fram filter for the Dodge cummins is just slightly bigger and costs $13.
Mr. Flibble
nxski wrote:Basically, you'll just need to go to an autoparts store and size up they're cheapest filters. The Fram filter for the Dodge cummins is just slightly bigger and costs $13.
That would do it! And then I could run twin filters too!
Mr. Flibble
nxski wrote:Basically, you'll just need to go to an autoparts store and size up their cheapest filters. The Fram filter for the Dodge cummins is just slightly bigger and costs $13.
That was a good idea! Cummins filters do run about $13 or so, and I think I will use this:
http://www.ebay.com/itm/Cummins-Diesel- ... 2892817%26
It is a Cummins Diesel Dual Remote Engine Oil Filter Mount~1"-16~PH3976A 1/2" HB Fitting
in case someone comes across this tread and the posting has expired. It is a fit with the 26 mm adapter.
Mr. Flibble
Now that I am looking more closely at this adapter; how would one hook up a npt pressure sender?
Given that pressure senders are sort of bulbous like these:
http://www.westach.com/products/ACCESSO ... /index.php
How would you make it fit? A short steel npt cable?
Mr. Flibble
I ordered the whole kit from Jackmaster. The guy was great; even calling me a few times from Oz to make sure all was in order.
I also ordered this:
http://shop.perma-cool.com/1226-Dual-Fi ... d-1226.htm $70.00 after shipping.
It should allow me to use these as dual filters:
http://www.amazon.com/gp/product/B000AR ... 00_s00_i00
Which are only $6.00 each! And, it is apparently also possible to install an Amsoil filter on this setup too. However, I think I will put on a centrifuge filter instead.
psilosin
Vehicle: L400
Post by psilosin »
Remember to take pics of the install. Should be cool when it's all done.
Mr. Flibble
psilosin wrote:Remember to take pics of the install. Should be cool when it's all done.
I will!
I am also looking at performing this variation on the bypass filter that I mentioned above:
http://www.dieseltruckresource.com/dev/ ... 69313.html
$160 for a centrifuge bypass install? Yes please!
Mr. Flibble
I am still waiting on all the bits - I will be creating a separate thread dedicated to this install and all the associated components.
One of the issues I can see is the mounting and draining of the Centrifuge. I am looking for options if you can think of any.
Pictures of the bottom can be found here:
http://beyondbiodiesel.org/forum/index.php?topic=52.0
You will notice it is quite large, and it is gravity fed. It seems that the Cummins people mount it on the oil filler cap - which works for their engine, but I doubt it will work for the space under the hood of the Delica.
Since the oil must gravity feed back, I am looking at using a drain to the oil pan; but I need to figure out how to configure that large hole to mount to an oil line. So far I don't have any good ideas.
thedjjack
Vehicle: 1989 L300 HITOP!!
Post by thedjjack »
pull the oil pan and drill a hole in it an put the return line (like the L300 from the vacuum pump on the alternator)? That is what I would do...not sure if you need to lift the motor to get the pan out on the L400?
bionic
Post by bionic »
tee into/enlarge the turbo drainback.
Mr. Flibble
bionic wrote:tee into/enlarge the turbo drainback.
Isn't That line under pressure after exiting the turbo?
Mr. Flibble
My Fram filters (at $5.99 each!) arrived today. Here are some comparison photos.
The Genuine Mitsubishi, is obviously the largest, it is also the most massive by a large margin. If I can find a scale I will weigh them. The Mitsubishi filter even outweights 2 of the Fram filters, it is extremely hefty! The Boshi is heavier than a single Fram, but lighter than the Mitsu.
The plan is to use two Fram filters in parallel, and a bypass filter for the finer stuff.
Filters
Filters
Filter Side
Filter Side
