1991 L300 DIESEL CRACKED CYLINDER HEAD ???
SunshineCoastMark
Vehicle: 1990 L300 Delica
Post by SunshineCoastMark »
Hey guys, looks like I might have cracked cylinder head, did a compression test, seems fine, no white smoke, just top rad hose gets bloated shortly after I start the engine and spills coolant into the reservoir tank.
Is there anything else that can be done to narrow down the cause of this problem.
If it is a cracked head , where should I buy one , should I stay away from cheap aftermarket heads, any help will be much appreciated , thanks.
Mr. Flibble
Re: 1991 L300 DIESEL CRACKED CYLINDER HEAD ???
Post by Mr. Flibble »
Check to see if there is oil in the coolant, or coolant in the water.
You may be able to inspect the engine with a probe cam.
It sounds more like you coolant system is clogged to me - that the pipe gets bloated and overflowing into the reservoir suggest to me a coolant blockage.
yojimbo
Post by yojimbo »
Run the engine with the rad cap off, if you get bubbles or a fountain of coolant, cracked head or gasket...
1994 L300 Jasper
1986 Scimitar 1.8Ti
gezzza
Vehicle: 92 exceed
Post by gezzza »
Sounds like you just may need to bleed the cooling system.
