Adjustment screw clarity
403delica
Vehicle: LWB L400
Post by 403delica »
Can anyone shine light one which is which? I have been told the 8m on top of the flap is the cold (fast idle) adjust, if this is the case what is the one on the lower pat of the picture with the 10m jam nut on it? i attached a picture... hope it works
Re: Adjustment screw clarity
What engine are you referring to? Are you talking about the idle? Have you looked at the shop manual in the L400 Dedicated Category Forum?
403delica
Vehicle: LWB L400
Post by 403delica »
4m40 yah I have a exploded diagram but it does not explain or state what is what I have no fast idle and am looking for adjustment I have adjusted the 8m one and also have been told the 10m one is the fast idle... So needles to say I'm confused and would like to know what is what... If neither adjustment works it look like its the wax thermostat in the pump
Evan
I mean this page: http://www.delica.ca/forum/the-1995-l40 ... -9266.html
I would think that your answers could be found in there.
403delica
Vehicle: LWB L400
Post by 403delica »
i have have gone through that many times and cant seem to find an answer it says that adjustment are under section 11I i believe but the section is not there.
11I covers idle set and adjustment
CREGAN
Post by CREGAN »
Hey, I kind of think this thread has the simplest instructions. I meant to try but haven't gotten around to it yet.
http://www.delica.ca/forum/problems-sta ... adjustment
Craig
403delica
Vehicle: LWB L400
Post by 403delica »
Yah I have read that thread before but have been told that the other one is the cold start.... Even if its not I would love to know what it adjusts? Any ideas? It seems to be linked to the throttle and high idle too
403delica wrote:i have have gone through that many times and cant seem to find an answer it says that adjustment are under section 11I i believe but the section is not there.
Section 11 is the engine, 4M40 being 11M, 11I is for the 4D5 Astron engines. Both of these are there (along with 11D, the 4G6 motor). I believe they both use the same injection pumps, not 100% on that.
I was glancing at 13F (Fuel Supply & Engine Control). It refers to accelerator cable inspection and adjustment. Could this help?
403delica
Vehicle: LWB L400
Post by 403delica »
i attached a pic of what i mean by 11I... its under the diesel fuel heading and is exactly what i need, its talking about idle etc. but i cant seem to find it :-(
Screen Shot 2012-10-28 at 7.38.41 PM.png (41.61 KiB) Viewed 5795 times
403delica
Vehicle: LWB L400
Post by 403delica »
Any more ideas? :-)
chris
Vehicle: 'Factory' L400
Post by chris »
Cregan's link is the one, especially page two with the link to Tttony's post on the UK delica site. It's all there.
403delica
Vehicle: LWB L400
Post by 403delica »
so the 8m screw at the top controls cold start advance and retard... the 10m ( bitch to get at ) is the fast idle set as far as i can understand... i think i have it now?
thanks everyone! :-D
403delica
Vehicle: LWB L400
Post by 403delica »
Well I have adjusted all screws and have no result... Still no fast idle. Vehicle starts fine, runs amazing well the glow plugs are on. Once they kick out its all down hill from there unless I use my foot to keep idle high
Any other ideas my fellow delica lovers?
mac_stang
Vehicle: 94' L400
Post by mac_stang »
I agree, I've had no luck adjusting the "cold" idle, I have only been able to increase the "hot" idle. In an act of desperation I cracked the fuel filter bleeder and pumped and pumped and left it with a POSITIVE charge. It has run 90 percent better ever since.
FYI, my l400 was having the worst starting issues since 2009, 70,000km ago...
Brad.
403delica
Vehicle: LWB L400
Post by 403delica »
Left it positive? what do you mean by that? yah im getting frustrated with mine :-( because it starts like an dream but after the glow plugs shut off all hell breaks loose
Return to “L400 Technical”
