CREGAN
Post by CREGAN »
CREGAN wrote:Did the winter maintenance. Changed the oil and threw on a new filter. Cleaned the bus bar with some vinegar and salt and it looked like a shiney brand new penny! Put in a new set of NGK's and changed the coolant temp sensor. Cleaned the K+N. Put in a new home-made cabin air filter. Bring on stupid winter- I am ready to go!
Craig
I am happy with the way the van is starting now! I am not sure wether it is the cleaning of the bus bar, new plugs or the sensor but it starts awesome. It was 5 degrees today and it fired right up. Previously, when it has been 15 degrees in the morning it started but burped, farted, sputtered and belched out some plumes of smoke. I think I must have had a faulty plug because the way it sputtered it semed like one, or more, cylinders was not doing what it should at morning start-up.
Feds
Post by Feds »
Finished repairing the 2 rust bubbles on the roof. 2 quarter-sized bubbles turned into a 3'x1' patch by the time the bondo/primer/paint went on, but it looks good from the ground.
While I was up there, I took off my TV aerials. Looks smoother, maybe it'll bump up the mileage too.
Now I'm trying to decide between circulating heater and 4-in-1 gauge.
LeeHammy
Post by LeeHammy »
-SeaFoam'd my crank, fuel filter and tank.
-Cleaned my K&N.
-TransTune'd (SeaFoam) my transmission.
-Drove it around till it all smoothed out then changed the oil with Synthetic 15W40 and put in a Puralator oil filter.
-Then drained off the trans and filled it back up with new.
-Going to change my transfer case oil to Redline 75-90 GL4-5 Synthetic tonight.
-Tomorrow I am flushing my steering fluid with the help of TransTune and putting in a magnefine filter on the return line.
Should be eady for hunting season and stupid winter after all this.
i like cheese
lrp374
Vehicle: 91 Super Exceed
Post by lrp374 »
Replaced the original green top Glow plugs with new Mitsubishi green top glow plugs I bought in the spring in Armstrong. Doesn't start any faster ( how could it I just tick the starter and it's going) but all cylinders are operating when it's cold which sounds better. I think only 3 plugs were working even though the resistance measured the same for all of them.
Larry
403delica
Vehicle: LWB L400
Post by 403delica »
Deli got a ladder! Oh yah
Evan
lettereleven
Vehicle: L400 Super Exceed
Post by lettereleven »
Anyways, I had my ss exhaust tip re-welded to the hanger. I was kinda surprised that JB Weld lasted as long as it did. Trust the Hurley to vibrate it off.
FFR - in case it wasnt immediately obvious, polypro rope does not work very well on exhausts; it tends to melt.
lettereleven
Wind visors were in rough shape so I gave them a clean
Order of operations
600 grit
1200 grit
Brasso polish
Silver polish
Turned out pretty great!
davidwwc
Vehicle: 1994L400 Delica
Post by davidwwc »
Lost the front heat a few days ago.,no good for the coming winter. Bought the thermostat from RSI as well as a set of glow plugs. They are both Hyundai made. Everything went well ,heat comes back and have to wait for a cold morning for the new glow plugs to show how it starts up. Check the old rusty plugs and got all different and funny readings.
DC
macro
Vehicle: L400 "The Invader"
Post by macro »
Finally got it back from the shop! One unfortunate byproduct of living in an apartment with street parking...
*Deep Breath*
All fluids and filters changed
New glow plugs (none were working.... what a difference!!)
New thermostat
New primer pump
Valve cover gasket
Front sway bar and tie rod bushings
Manual glow plug switch
Still to do, IP seal, rear bushings, temp gauge sensor, maybe a new battery and alternator belt. Aaaaaaaand a lift kit and new tires..... :-) :M
mrraulduke
Vehicle: 96 L400 SWB
Post by mrraulduke »
I did my glowplugs last night as well. From a coughing, sputtering beast to a smooth purr with minimal cranking. Next is valve cover gasket to get rid of my leopard spot patterned carport floor!
josh
Vehicle: L300 poptop gasser
Post by josh »
Yesterday I modified the rear right hand side... a nice bruise on the highway. Today I pulled out the interior carpet, and started taking out all the inside trim. Not bad for day two of ownership.
Josh
josh wrote:Yesterday I modified the rear right hand side... a nice bruise on the highway. Today I pulled out the interior carpet, and started taking out all the inside trim. Not bad for day two of ownership.
Josh
I'd expect nothing less from you, Josh. You have a name for her yet?
josh
Post by josh »
A name for her has not "struck" me yet...
thelazygreenfox
Post by thelazygreenfox »
Josh I guess you can't call her "gasser."
wayne
TLGF
glenn
Post by glenn »
Picked it up at the WWL terminal and drove it home. There were some nice cars there - I especially liked a couple of the old school minis - and of course there were a bunch of L400's
Glenn
http://www.vurv.ca
L400 and L300 consoles
