Possible to reset speedometer?
lettereleven
Vehicle: L400 Super Exceed
Post by lettereleven »
I ripped apart my dash today looking to annihilate some dash crickets.
I took the opportunity to clean the speedometer and tach guages (wow what a difference!).
All went well on re-assembly, except that I appear to be going >180kmph while parked.
I know I can correct this by re-ripping it apart and flicking the guage over, but that would be a total hassle.
Does anyone know if there might be a shortcut?
Jamie.
Re: Possible to reset speedometer?
it's not grounded
lettereleven
Did I forget to reconnect the ground?
lettereleven
Woohoo! It fixed itself. No need to disassemble it all again.
If it happens again, you should check the plug connections are tightly mated.
lettereleven
Thanks very much for the suggestion.
J
Return to “L400 Technical”
