Rejuvenate an L400 front sunroof seal
lettereleven
Vehicle: L400 Super Exceed
Post by lettereleven »
With thanks to Drumster, I believe I have fixed my leaky front sunroof. Thought I would share it for any others who might have an old gasket.
I have taken two approaches to fixing the leak. Previously, I took the overly cavalier approach and siliconed the whole thing shut. Worked great but has clear implications for functionality.
The second road taken was to revive the gasket a bit with some detailing product. Then stuff a piece of cotton string under the gasket. The string flares up the gasket enough to seal but not so much it causes problems.
So far it's working very well.
Lesson learned for me: only silicone things closed when you are confident that you will never ever ever ever open tem again. Silicone removal is a wretched task.
Re: Rejuvenate an L400 front sunroof seal
the string is a good idea. 8-)
this is what I've been using in the past. seems to work well on the sunroof membrane as well.
http://www.delica.ca/forum/water-gettin ... -3953.html
cd_photo
Vehicle: 1994 Delica L400 Exceed HR SWB
Post by cd_photo »
This is a tip i can really use right now. One question though. How did you get the string to stay in place on the sunroof?
Thanks,
Colin
Pajero
Vehicle: 94 Pajero
Post by Pajero »
cd_photo wrote:This is a tip i can really use right now. One question though. How did you get the string to stay in place on the sunroof?
Thanks,
Colin
I think he put it under the gasket to push it out a bit, not on top like in the picture.
Joe
lettereleven
Yes the string is pushed into the seal on the interior side of the sunroof.
cd_photo
Post by cd_photo »
Ah, I get it now. Thanks! How hard is it to remove the sunroof?
