Oil Filter Numbers for an L400
I hear 6" long and good girth is a decent start. Anything shorter might not provide proper duty cycle. With good liquid flow pumping through it tends to require more "servicing" and risk leaking if too much pressure is applied... A tight adjacent seal unit will ease the interval change of fluid. It's a simple fact of proper lubrification, simple really. Overweight unit will certainly shorten the life expectancy of these items...
Re: Oil Filter Numbers for an L400
all this talk about size and cooling pressure from the administration and corporate sales is making me feel inadequately inadequate. I have two filters and they are small. Should I increase the girth? Maybe I should substitute girth for length. I'll ask the ladies.
rezdiver
Vehicle: 1991 L300
Post by rezdiver »
Just ask Hobbs
Reza
1991 Delica L300
http://www.iltisforum.com/
psilosin
Vehicle: L400
Post by psilosin »
rezdiver wrote:Just ask Hobbs
post of the day :-D
nxski
Post by nxski »
This thread went from bad to awesome in one day! I'm now, more than ever, a complete supporter of psilosin's 'like' / 'thanks' idea! :-D
CREGAN
Post by CREGAN »
Here is a picture of the difference in size between the Donaldson that is recommended for our vehicles and the Sure Filter that Mardy sells. I bought one just to see the difference.
I have decided that I am just going to stick with the Sure Filters. Cost and performance wise they can't be beat IMHO. So... any of you Paj owners here in Edmonton want to trade me some beer for a Donaldson filter?
Craig
djelica
Vehicle: L400 Super Exceed
Post by djelica »
Anyone know if the Fleetguard FL387 filter is a good cross reference.
I get my filters from Western Star Trucking that used to be a Fuso dealer and was originally getting the MEO88532 for about $23. The new ME228898 (same filter new number) is now in the $40 range.
The Fleet Guard (Cummins really) is about$25 from Western Star and they have it as a cross reference, but it is nice to be certain with these things.
Cheers, Darren
djelica
Post by djelica »
OK it is actually a Fleetguard LF 3817 that I was wondering about. Picked one up for about $29 total (in Alberta) as opposed to the Fuso ME 088532 that it should replace (says so right on the box so I hope this is good) that was costing about $45.
Used to get the same Fuso filter # ME 228889 for $23 from the same place. Hope this may help someone and at my next oil change I will let you know if it does indeed work.
Later, Darren
psychadelica
Vehicle: L400 Series II Super Exceed
Post by psychadelica »
Hey guys,
Just about to do my first oil change on my new van - a '98 Series II L400. Lordco sold me a Fram PH8936 but from what I read in this thread I'm getting the indication that it might actually be for an L300. Anyone know the definitive filter type/number to ask for with my van if I walked in there today? Also, it appears you need to remove a 1 or 2 piece skid plate to do the oil change. I assume that's correct? Any help would be awesome!!
Feds
Post by Feds »
I use Fram PH9055 on my L400. You may have gotten the wrong part.
dah_hunter
Post by dah_hunter »
So the Baldwin BD7095 is fine to use for the 4M40..
they are $17 on Amazon.com.. so thats pretty reasonable.
Its all about the Right Way:
http://import-era.com
Krazyistkarl
Vehicle: 96 2.8D and 98 V6 SWB HR Chamonix's
Post by Krazyistkarl »
Bumping this cause I just realized I've put on 5000km after two trips to Bc and back and now need to do another oil change. I used the Donaldson filter last time, and noticed some leaking around the seal and tightened up the filter again by hand (I think it worked itself loose) I switched to full synthetic Rotella T6, what are you synthetic guys going with for a change interval? Every 5000km or longer
The van came with a sakura filter from RSI, which is bigger then the Donaldson
macro
Vehicle: L400 "The Invader"
Post by macro »
I do every 5000km or 3 months (5000km is usually first). For me, I do a lot of city driving and highway driving so I figure it's cheap insurance on engine life. I use an app called Road Trip to help me keep track of everything, you can set reminders and whatnot.
I would guess if you do mostly long distance highway trips the oil lasts longer. I have no basis for that opinion though, just my own thoughts.
