- Big-Bird
- Vehicle: 96 PE8W Spacegear
Neither one of the lights was 100% complete.....will be using them to make one good unit complete with LED upgrade. Will look at doing an engine bay mount with the other one.... Its dark under that hood!
- Shaun Van Ramen
- Vehicle: '91 Exceed
I managed to finally add center-cup holders to my "behind the front seat" counter. Also added a few strips of moulding so the tissue box will stop sliding every time I turn a corner.
- vancupholder_1_1.jpg (73.14 KiB) Viewed 5698 times
BAHahahahahahaha
- 1994delicaman
- Vehicle: KTM
Re: what did you do WITH your delica today
I installed a manual switch for the intercooler fan today.
2006 smart car diesel CDI
2011 KTM 990 Adventure
2015 Mercedes GLK250 Bluetec
2018 KTM Superduke 1290 R
- Big-Bird
Installed a factory flashlight today in the back.
Before
After
Before
After
The only thing I've done lately is rip the spotwelds out of my seat mount, maybe I should diet...
1994 L300 Jasper
1986 Scimitar 1.8Ti
1986 Scimitar 1.8Ti
- CREGAN
I finished fabricating some brackets to hold mudflaps on the rear wheel wells. Used a cardboard template and bent some steel, drilled some holes and gave 3 coats of tremclad.
Hey, I have noticed some surface rust forming in the rear under and around the spare tire. I want to get rid of it so what are your thoughts on these products? I was thinking zap it with the rust converter and then use one of the 2 types of undercoating crap. Thoughts? Product reviews?
Craig-
- Vehicle: delica L300
I would use the same product so you know they are comparable, but I would throw a layer of paint over the rust converter then over the undercoating a good layer of Fluid Film
Then you would have your total protection
Dustin
Dustin
In my experience rust converters etc only ever really attack the surface layer, so either sand/wire brush it down so its a very thin layer of rust, or por 15 it, which seems to work even on thicker rust.
1994 L300 Jasper
1986 Scimitar 1.8Ti
1986 Scimitar 1.8Ti
- LeeHammy
I removed the old gold pinstripes and 2800 decals and replaced them with something a little more clean, new and different. Black I know is simple but it works and the red has a hint of orange so it looks retro esk.
- Before
- IMG-20120621-01300.jpg (43.62 KiB) Viewed 5522 times
- After
- IMG-20120622-01305.jpg (95.17 KiB) Viewed 5522 times
i like cheese
- LeeHammy
I also did a cut polish, polish, wax, and detail. :D now the mud rolls right off the paint... Slippery. (This was last week, not today)
- IMG-20120624-01324.jpg (136.66 KiB) Viewed 5521 times
- IMG-20120624-01325.jpg (118.95 KiB) Viewed 5521 times
i like cheese
LeeHammy, your Pejero sure puts that civic to shame and it's not just because it looks like every other modified civic.
- LeeHammy
Haha thanks! Maybe also because my modified JDM can go over a speed bump? :P if only there was a 4x4 category at that "car" show...sigh.. Was fun dressing it all up though! Major difference in the paint feel, nothing seems to stick to it, dust water etc. :D
i like cheese
I finally got hold of a MPH speedo fascia and installed it, then gps checked it, it was surprisingly accurate. In the post is some replacement LED's for the DELICA lights at the back, after that I may fit the OOGA horn I had in my landy, I'm thinking a big red push button next to the vent above the stereo, easy reach for both me and the passenger, and a label that says "OOGA" under it, then when the passengers ask what an ooga is, invite them to press it.
1994 L300 Jasper
1986 Scimitar 1.8Ti
1986 Scimitar 1.8Ti
- tonydca
AHA! So *you're* the reason the weather's turned crappy again! The ol' wash-and-wax rain danceLeeHammy wrote:I also did a cut polish, polish, wax, and detail. :D now the mud rolls right off the paint... Slippery. (This was last week, not today)
- CREGAN
Made myself a cabin air filter. Remember reading here a while ago about them being non existant and got tired of the used dryer sheet I had been using always falling out when I popped the hood so I came up with a little invention. I purchased some new charcoal prefilters for our bedroom air purifier from London Drugs and realized they would work great to replace said dryer sheet. $15 (enough in the box to probably make 4 or 5) and 4 of my wifes bobbie pins to hold it in place. Works well.
Craig
Craig
