legionnair
Vehicle: delica L300
Post by legionnair »
Yeah sorry about the pics forgot the phone rotates them funny. I mostly wanted a clean look, I have one more panel to make for the other side. Then I will put two RV/deep cycle batteries and LED lighting and a couple 12 volt power ports to run some toys. I will charge these off the alternator when running but will hook up a Cetek charger to charge them when I am near A/C, with an isolator to protect the starting battery.
Thanks for checking it out
Dustin
CREGAN wrote:
legionnair wrote:Started my camperization project
That looks really good! Did kind of give me a sore neck looking at the pictures though :-) Looks like an actual factory conversion, not a back-yard carpenters rendition of one. Nice work
Craig
I put my laptop on it's side. That's a nice, clean job Dustin, well done. What do you have planned next?
legionnair
Ok so I had some left over wood and carpet plus some 5.5 " speakers so I built this
The box gives them some bass and I think keeps up with my clean theme. Not bad the platform/bed and speaker box for $100
Dustin
Morganizer
Post by Morganizer »
I finished powder coating my bull bars! and painted the plastic bits with Rocker Guard.
Okay, so I didn't do all this today; I've been picking away at it for a few weeks. But I re-installed the fog lamps today.
legionnair
Major improvement, well done. How much did he powder coating cost?
legionnair
New fishing rod holder installed, not bad for $10
legionnair
Added a storage rod for hanging my large saddle bag
Rod is made of rebar and the brackets are custom from some flat bar
The bag is for toilet paper, soap, firstaid kit, etc all lighter stuff
legionnair
Well finally got tired of looking at the rust spots at the bottom of the rear window. So I pulled the glass and cut out the bad spots welded in a couple small pieces( I am not a body man). Then cause I did not want to paint the entire rear door I painted a 2" strip around the window and then finished it with some vinyl pin stripe looks way better than before.
What do you think
Dustin
CREGAN
Post by CREGAN »
That turned out really good Dustin! Looks legit.
Craig
psilosin
Vehicle: L400
Post by psilosin »
that looks too legit to quit. Nice work.
Big-Bird
Vehicle: 96 PE8W Spacegear
Post by Big-Bird »
Got tired of looking at the paint chips on my intercooler scoop....Sand, wash, prime, guide coat sand, wash, paint gloss black.
BEFORE Image
AFTER Image
tonydca
Post by tonydca »
Replaced my interior dome lights with 15-LED replacement units from an LED lighting store in North Van. $35 later my interior is awash in light!
BONUS: I discovered that my "burnt-out" door warning light was in fact due to the connector having popped off inside the door, causing an annoying rattling noise (the loose wire inside the door) at certain speeds/RPMs.
Now all interior lights work and annoying rattle is gone. Woot!!
psilosin
Vehicle: L400
Post by psilosin »
Rewired the rear L400 RED/WHITE flourescent controller to use LED strips instead of the gimpy flourescent tubes. Credit for the idea goes to Diver from his post on the UK Delica site.
The operation was simply remove a couple of the original connector strips to make room for a terminal strip. Cut + power from board and wire direct to terminal strip. Then run a - wire from each of the - terminals from the switch to the terminal strip to do the switching from sexytime red or business white. Check out Divers post on the UK site for more pictures of where to do what. I used 4 strips of white LEDs and 2 strips of red LEDs
You could be more creative and rewire to use the dimmer switch etc but I just wanted simple ON or OFF of either the white or red LEDs. Plus I only had 15minutes on my coffee break to git'r'dun.
Here are a couple pics of the mods to teh board. Pics in the vehicle to follow sometime...
Before
Before
After
After
Big-Bird
Post by Big-Bird »
Got my 12volt emergency flashlights in the mail today. One from Britain, one from the US. Should be mounted by the weekend boyz!
And people said these were hard to find! Bwaa ha ha ha!
CREGAN
Post by CREGAN »
Big-Bird wrote:Got my 12volt emergency flashlights in the mail today. One from Britain, one from the US. Should be mounted by the weekend boyz!
Why 2? Are you really planning to be in an emergency, or is one a back-up for the back-up? :-) Did you track down a triangle?
Craig
