We have numerous posts on everything Delica.
The question is: how to correctly use the search engine?
Even though the answer is likely here, I often give up searching and just ask the question because the search either brings up waaaay too many posts to rummage thru or else I've failed to phrase my question in just the right way.
For example. right now I'm wiring up propane injection on my '94 L400 and I need to tap into a 30 amp, (edit: incorrect figure; only 1 amp is drawn) "key on only" power source. (Ignition off = no juice). Although I'm sure this is quite elementary for anyone with even a general aptitude for such things, I'm not electrically inclined and so need advice on this. There's very likely something buried in the site but finding it has eluded me so far.
Your help on either using the search itself or on locating a suitable power terminal would be appreciated.
