L300 Jasper "Sunny" in Nelson, BC
Jordan
- Vehicle: 89 low roof L300
-Removed decals
-Removed lower plastic trim
-Rockerguard/painted lower half
-WVO Conversion
-2.5" from turbo to muffler, 3" side exit exhaust
-Spare moved to front for WVO tank
-EGR deletion An advantage to having your stereo stolen is more room for gauges.
Volt, Boost, EGT on the top
WVO tank, hole for future gauge, volume for ipod (or anything), wvo switches on the bottom.
Such a relief getting the outside/underneath things done before winter.
Before:
-WVO Conversion
Before:
- BCDelica
Re: L300 Jasper "Sunny" in Nelson, BC
Very nicely detailed Delica! That front mount spare looks great, though all that bare space in front of the tire just calls out for some cool, wild, or tacky design. Which would look even better as your Delica is decal-less. Maybe something that's in the face of everybody else who stops at the gas pumps?
How about more info on you WVO install and WVO tank install (looks like an aluminum tank)?
Best Regards,
Kevin
Best Regards,
Kevin
Call me BCDelica-less-
Jordan
Thanks, All the work was done in front of my house, I got the components for the WVO from AndrewH; Hydraforce valves, vegtherm, 1/8" 78l Aluminium tank and did it piece by piece over the last month.
- Luna-Sea
Very nice work!
- almac
i like how you rock guarded the lower half of your deli. i considered doind that to mine.
is it textured? have any closeup shots?
also like the digital gauges. what brand are they? i think i would've reinstalled a stereo tho.
al
al
Jordan
The rocker guard is textured , it has a matte finish that attracts dust after a couple days so I did a black gloss over it, it was a make work project after I found some rust hiding under the plastic trim. I also did the rocker guard on the bull bars when I maneuvered them for the front spare mount. I have a stand on the dash for an ipod and run it direct to an amplifier, there is a volume control in the dash piece next to the wvo switches. Just can't play the radio and now there isn't anything (easy or visible) to steal, all my media is on my ipod and I am much happier with this stereo setup because of its simplicity. Gauges are glowshift.
Jordan
Changes over the last year or so.
-2" Lift
-31" Tires
-Stripped the AC/interior
-Insulation/sound deadening
-front console
-2" Lift
-31" Tires
-front console
- Insulation
- 5.jpg (121.02 KiB) Viewed 10352 times
- front console 2
- 4.jpg (80.8 KiB) Viewed 10352 times
- front console
- 3.jpg (91.47 KiB) Viewed 10352 times
- Dynamat
- 2.jpg (146.59 KiB) Viewed 10352 times
- 2" Lift, 31" tires
- 1.jpg (101.18 KiB) Viewed 10352 times
- Luna-Sea
Jordan
Insulated the floor
Installed 1/2" subfloor and walnut hardwood
Wow Jordan, I like the way you've laid the hardwood floor, nice touch.
delichris
- Vehicle: L300 Starwagon
I removed the Heater/Ice box in mine and was thinking about making a similar console for the speakers and storage up front
