i have a 92 L300 exceed Turbo diesel 5 spd.
My turbo maxes out at 10 psi. It Idles at 0, there is no vac pressure.
How much vac pressure should there when idling?
How much boost should i get from the turbo?
How can i find out if my turbo is working properly.
- Vehicle: Mitsubishi Delica L300 Exeed
- sub-arctic
- Vehicle: L300 Super Exceed
Re: How can i find out if my turbo is working properly.
as far as i know the manifold will produce no vacuum pressure, thats why the back of the alternator has a vac pump built into it to run your brakes etc. there wont be any boost at idle because the turbo wont spool until higher rpm. not too sure on the boost psi though. anyone else have the numbers?
hope this helps
hope this helps
- Vehicle: delica L300
10-11 is very standard, some people set hem higher Max is 15 but done at your own risk.
Sounds like yours is working great
Dustin
Dustin
"How can i find out if my turbo is working properly"
If you can achieve/maintain over 50 km/h on the highway...
- jwfchase
- Vehicle: '92 Super Exceed
mararmeisto wrote:"How can i find out if my turbo is working properly"
Which highway?....
When things go better on the Coque.... How's that for product placement?jwfchase wrote:mararmeisto wrote:"How can i find out if my turbo is working properly"
Which highway?....
