L400 Super Exceed has Yellow C/D light flashing
mike_mitro@hotmail.com
- Vehicle: Delica Super Exceed 2800
Tried to put L400 into 4wd and now C/D light is flashing and won't go off. The dashboard indicator never indicated all wheels engaged with 4 tires lite up green.
Re: L400 Super Exceed has Yellow C/D light flashing
responses to your other thread : http://www.delica.ca/forum/trouble-shif ... 12418.html
one of two things
either the sensor is sticking in which case you need to 'massage' it by putting it through all the 4WD gears on/off/on/off
or
vacuum solenoid (one or both) are dead/dying and need to be replaced
one of two things
or
monnomania
- Vehicle: 96 L400 lwb clr
