Recently I removed the K&N in order to look at the turbo and different things in preparation for installing Propane Injection kit. I'm really glad I did that because what I discovered was that the length of K&N Aluminum "accordion" ducting between filter and air inlet had been vibrated and pulsed nearly to death and there was all kinds of aluminum bits and shards gumming up the filter. The ducting itself had worn right through and air was being drawn in from the engine compartment. I'll post pics of the damaged ducting later.
The space from Apollo to opening in fender (to outside) had previously been about 14" long. What I've done now is, after repositioning the Apollo, I returned the original Delica air duct that went from fender opening to stock air box. With stock box in place this duct had been held in position by having the stock box itself press firmly against it - which couldn't happen with the K&N in use. However, I used some wire to hold down the duct using two bolts located close to opening. It's really firm now. As mentioned, I'll get some pics cuz I'm sure that won't make much sense without them. So now the Apollo is connected to stock rigid plastic duct, with only about 3 inches of the thin K&N Aluminum ducting between.
Of course before putting things back together I thoroughly cleaned, dried & re-oiled the filter. I also noticed a fair bit of fine dust inside the silicone intake ducting between filter & turbo. So although the dangerous chips and chunks of Aluminum were kept out, it looks like quite a bit of dust has been getting past the Apollo.
The K&N Apollo is, IMO, good for freeing up space and letting more air in to the engine but it does not do as thorough a job of filtering as I'd like. I'm not too impressed with that aspect so I think I'll buy one of these to fortify it...
http://www.race-mart.com/KN_Filters-KNE-RC-5052DK.html
Cheers!
