nvanadm's Derelictica
nvanadm
Post by nvanadm »
1993 Mitsubishi Delica Super Exceed L300 (StarWagon)
Purchased from Mardy (Amazing Auto Imports) in September of 2008 w/ 158, 000kms.
I guess it's about time I start a thread to keep all my projects/modifications in one area.
carrier installed.jpg (123.2 KiB) Viewed 21240 times
nvanadm
Re: nvanadm's Derelictica
Post by nvanadm »
Our first project that we worked on was making some curtains.
Finished curtains.jpg (42.86 KiB) Viewed 21422 times
You can check out the build thread here... http://www.delica.ca/forum/homemade-cur ... -5202.html
nvanadm
Post by nvanadm »
Next we built some storage drawers and a folding sleeping platform.
finished drawers.jpg (68.72 KiB) Viewed 21421 times
bed drawers.jpg (78.85 KiB) Viewed 21407 times
You can check out the storage drawers build thread here... http://www.delica.ca/forum/drawer-syste ... -8347.html
We also built a shelf for our electric cooler.
cooler shelf.jpg (89.66 KiB) Viewed 21407 times
nvanadm
Post by nvanadm »
Two winters ago I swapped out my auto hubs for some manual hubs. I don't drive my delica during the winter months here in Ontario so I've only used them once, but they worked great!
auto hubs.jpg (80.63 KiB) Viewed 21420 times
manual hubs.jpg (83.59 KiB) Viewed 21420 times
nvanadm
Post by nvanadm »
post outdated
nvanadm
Post by nvanadm »
Today I finally installed the Ford Taurus cup holder that I purchased off ebay quite some time ago ( http://www.delica.ca/forum/l300-cup-holder-11839.html ).
I removed the small "pocket" that was under the stereo.
cup holder.jpg (44.97 KiB) Viewed 21406 times
cup holder installed.jpg (71.32 KiB) Viewed 21406 times
cup holder open.jpg (66.83 KiB) Viewed 21406 times
I had to do some trimming to the cupholder and there were also two small bolts that were holding the "pocket" from moving side to side. Not sure how Mardy's guys managed to get those bolts in there but I had no idea how to get them out...so I also used the dremel for that too. Overall it was pretty straight forward.
Don't judge my van's apearance on these pictures :-D ... they really show the dust from the cutting.
nvanadm
Post by nvanadm »
While camping in the hot/humid/mosquito buzzing part of Canada we call Onterrible, we tried to come up with a solution to be a little cooler while sleeping at night. We had the idea for a net that would surround us and then we found this... We didn't buy ours at Canadian Tire, but they do carry the exact same one.
The little hooks in the corners and on the sides (6 in total) slide perfectly in place and don't fall out.
fexlboi suggested using magnets to hold the mosquito net up higher so that it doesn't sag. I think I will finally try that this summer.
nice round up. The wooden handles look familiar :wink:
Nice job, the net is a nice touch. I look forward to the additional posts. A very tidy job, indeed.
nvanadm
Post by nvanadm »
Yesterday I did the seafoam IP purge. The sound of the engine before and after seems exactly the same, but I had to go out to the hardware store to pick up a few things and boy was it smooth!! Going to go for a drive today and see how it feels. I don't expect to see a gain in power but I'm satisfied with the smoothness for sure.
Here's my setup (thanks to profister and jfarsang for previous "how to's" - http://www.delica.ca/forum/diesel-syste ... -5082.html )
Purge Set up.jpg (90.95 KiB) Viewed 21354 times
psilosin
Vehicle: L400
Post by psilosin »
This is an excellent thread, one of the best in a long time. Very enjoyable to read and contains great info and pics. Great work on your L300.
lettereleven
Vehicle: L400 Super Exceed
Post by lettereleven »
Great post and pictures. Thanks for sharing.
Also really appreciate the effort on the seafoam video. I am going to do one in the summer and your video will be a great reference.
J
nvanadm
Post by nvanadm »
Went out to Craig's (Bonsai Rides) workspace today to change the oil and transmission fluid and filter.
Used Seafoam in the crankcase before I left to go out. The oil change was routine.
However, this was my first attempt at changing the transmission filter and fluid. In the end it wasn't so bad, but there was a minor setback. When I removed the transmission filter (screen) the gasket was stuck on the transmission so I went to peel it off and it came off in about 30 pieces, but that wasn't the worst part. Where the bolts hold the filter on, the gasket was REALLY stuck. I had to use a razor blade for about 30 minutes to get all of the gasket off. Good learning experience I guess :?
nvanadm
Post by nvanadm »
outdated
nvanadm
Post by nvanadm »
Today I also removed the front side steps. I just never really liked the look of them. I know they are supposed to help protect, but after looking from all different angles, I don't think they would help much. I don't usually go offroad anyway so I'm not too worried.
Before pictures
Lt step before.jpg (74.73 KiB) Viewed 21296 times
rt step before.jpg (74.86 KiB) Viewed 21296 times
After pictures
Lt step after.jpg (72.5 KiB) Viewed 21296 times
rt step after.jpg (76.91 KiB) Viewed 21296 times
Return to “Member Rides”
